Question about Viper Ride Contraband Snowboard Bindings
Do the ride viper contrabands fit on the new burton boards using the channel system or the retro fit system for the new burton boards
  • 66 Answers
They wont fit directly as Ride bindings are made of very lite metal and need all four screws to stay secure. The best idea is to buy the matching Burton binding or avoid the channel system and stick with 4 x 4 brands
Posted on Jun 08, 2010
How do I hook up the Retro Duo nes/snes system to an older tv that has no a/v connections. I do have a Direct tv cable box but when I hooked the a/v cables to it absolutely nothing happened
Do you have a VCR that can hook to the TV that has the proper hook ups for your game system? Be sure your TV is on proper channel for your VCR to work (test it with a VCR tape and see if it plays) then change your channel on your vcr until it shows your game you have in your system hope that helps good luck
Dec 11, 2014 | Retro-Bit Retro Duo NES/SNES System Mascot...
How do i connect retroduo to my tv
Most likely through a coaxial cable or RCA cables, it would be the antenna in to your tv or the RCA Video in and then tune the TV to channel 3. Unless this is a new system and uses
Oct 15, 2013 | Retro-Bit Retro Duo Twin Video Game System...
I recently bought a Blunt 155 and noticed two threaded inserts appeared to have damage when removed for adjustment. Can these be replaced?
The threaded inserts are built into the layers of the snowboard so they can not come out while riding. Imagine if they were able to be pulled out and one came out while you were riding - your boot and binding would lift right off the snowboard. You can try to fix the threads with a tap (threading tool), but otherwise they will not be able to be fixed and you would have to get a new board. If you just bought the board, you could try contacting Burton about having it replaced.
Jan 29, 2011 | Burton Winter Sports
I have a 1993 Chevrolet c-1500 truck with A/C. It is not blowing cold. I noticed that the sticker on the compressor says R-12. What can I put in that is safe?
You Must Change over to 134-A and this Requires Replacment of All Internal Rubber "O" Rings
Although I Have Purchased the ADAPTER Fitting and Just Filled My Personal Vehicles With 134-a With No Problem
Jun 14, 2010 | 1993 Chevrolet C1500
Boy just got a burton hero board, put on his danny kass bindings. The EST system for binding attachment seems to stink. Only two screw attachment, they immediately loosen up. How to attach tighter?
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
Mar 06, 2010 | Burton Winter Sports
How do Lamar bindings line up against burton
Burton has a different pattern for their bindings then everyone else. The good news is that the standard pattern will fit on burton boards. You just need to use 4 bolts on the lamar bindings rather then the 3 you would use with burton.
Oct 18, 2009 | Lamar Winter Sports
I just want to ask if the Burton P1.1 2009 LARGE bindings will fit to my 24cm width board Thanks in advance
Should do... Though to be safe I'd take a measurement of the board width to the shop with you and have a look at the bindings on a board of similar width..
Better still bring the board and your boots in with you and have them fit the binding and then try it for feel before you buy..
Sep 30, 2009 | Burton P1 SNOWBOARD BINDINGS SIZE LARGE...
Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Viper Ride Contraband Snowboard Bindings Logo
124 people viewed this question
Top Viper Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Viper Winter Sport Expert? Answer questions, earn points and help others
