Question about Dell HP-150SS (HP150SS) 150-Watt Power Supply
150 W ATX Power Supply HP-150SS
How can start this whitout pc ? This is not a normal psu , is a DELL. Shorting the green (Pin 14) to ground doesn't work on the Dell power supply. It does NOT conform to ATX standards. Pin 14 on this power supply is a ground. I haven't been able to find the right combination either though, but I know the grey wire (Pin 11) starts the process. The problem is another set of pins must also be shorted for it to stay powered up, but I haven't been able to figure out which.
  • 97 Answers
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
HP-233Snf
Anytime you see a Green wire in a computer, (Personal Computer), power supply's ->power cable, it is for the Soft Power On function.
This way there isn't a cable, (Cord), going from the Power On switch to the power supply.
These are ATX style of power supply's.
The Black insulated wires are Ground wires. ALL of them.
There was a older power supply made, and this was the AT style.
To provide a solution, I'm going to give you some information on the power cables, for Both of these styles of power supply's, then some advice.
1.This is info, and photos of the older AT power supply's power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
2.This is the newer ATX style power cable, and more specifically the 20-pin version,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll down the page to view the 24-pin power cable, and then scroll down some more, to view the 20+4-pin power cable.
ALL ATX design power supply's use Pin 16 for PS ON, (Soft Power On), which is a Green wire, and ANY Black wire. ALL Black wires are a ground. Pin 15 has a Black wire, and is normally used to put a jumper in, from it to Pin 15. This turns the power supply on. There will be a small spark, and the chance of getting shocked.
What you are doing essentially, is using a personal computer power supply as a laboratory power source, therefore I cannot advise you further, as it is a Safety Hazard.
Jul 31, 2009 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
POWER SUPPLY
ATX PSU are enabled by a signal on the green wire pin 16.
Shorting of pin 16 to ground (0VDC) will enable the PSU
Refer HERE
Also refer HERE for the 20 PIN ATX
Jul 01, 2008 | Intel (ATX350P4) 350-Watt Power Supply
HP-150SS
Hello diallo
Do you mean which wire is the +5VDC on?
There is an industry standard for coloring of computer power supply wires.
+5VDC is on the RED wires.
HERE is a link on Computer Power Supplies "ABCs" that will be very helpful to you, I think.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Dell HP-150SS (HP150SS) 150-Watt Power...
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
351 people viewed this question
Alun Cox
