Question about KitchenAid KUDR24SE Built-in Dishwasher
Dishwasher stopped mid-cycle. No power lights etc. Checked fuse box etc. no luck. Any ideas what could have caused this?
  • KitchenAid Master
  • 3,361 Answers
There is a thermal fuse in the control panel that must be replaced.
It is on the right hand side and has a black and a white wire going to it.
Posted on Apr 23, 2010
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Same problem!
sounds like the main control board needs to e replaced this is the most likely problem
Sep 16, 2009 | Kenmore 15129 Built-in Dishwasher
Works then no power Kenmore 16352
first thought would be a loose connection in the junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
I have a kenmore dishwasher and it stopped in the middle of a cycle and water is in the bottom. No response from the dishwasher, plug is ok and not tripped. Is there a reset button or not?
When the dishwasher stops in mid cycle and there is no console lights illuminated, then more times than not the thermal fuse has gone out. The thermal fuse is located on the power supply board which is located inside of the console. you must remove the console in order to gain access to the power supply board. the thermal fuse is white and has to wires connected to it. a black wire and a black wire w/white stripe. disconnect the power at the panel box first, before you start. you then remove the old fuse, by "plucking it up" w/ a small flat head screw driver. then you remove the two wires connected to the fuse and place the new fuse in the spot ot the old fuse and place the wires on the new fuse. any order of placement will work. There is a fuse kit that will handle the electrical surges that may have cause the fuse burn out in the first place.
Apr 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
