Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Frost accumulating on back of fridge - service light blinking
Temps are flashing between Freezer 0 refrigerator 42 and Freezer 6/refrigerator EC while the service light is on.
There is frost accumulating on the back of the fridge above the crisper and my veggies are freezing.
Also I had the seal on the door replaced two months ago. PRior to this replacement, the above issues were not evident.
    Scholar:
  • 126 Answers
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Posted on Apr 24, 2010
Freezer runs but will not freeze
Check for low freon first, You need an expert who has testers as well.
Jun 29, 2015 | Whirlpool EV250NXT Upright Freezer
My sub zero service light and EC 24 are flashing, fridge is getting warmer...suggestions?
The ec 24 alarm is from a sensor that is located behind the freezer wall and connects to the control board in the ref. When the temp gets to a certain point the sensor will trip giving the alarm. If the temperature in the freezer is gone up but is around the 20 -30 degree F range, I would remove the grate that covers the compressor and check to see if the fan is running and if the coils are dirty. Either one of those can cause temps to go up. If the fan is running and the coils are clean, Call a service company because you possibly have a sealed system issue
May 06, 2012 | Sub-Zero 632 / S
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Refridgerater doesnt get cold enough.
Things to check.......Is the evaporator (freezer) fan motor running? If not you could have a bad motor
Do you see a build up of frost on the interior rear wall of the freezer? Problem in the defrost system. This includes the heater, terminator or control.
In addition a bad fresh food damper control or blocked return air duct could be restricting airflow into the fresh food compartment.
Ideal temps should be 0 to 10 above in the freezer and 36 to 42 in the fresh food compartment. This can be measured by submerging a thermometer in a cup of vegetable oil that has been in the freezer for 24 hours. The same can be done in the fresh food compartment where a cup of water will do the trick. Higher freezer temps could indicate a more serious problem in the sealed system.
Apr 28, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Freezer workss but fridge dont
Check for a frost buildup on the interior back wall of the freezer. If you find this, a problem exists in the defrost circuit (heater, terminator or control).
Also verify that the evaporator (freezer) fan is functioning.
A failed damper control can cause this condition as well.
Proper product temps are 0 to 10 in the freezer and 36 to 42 in the fresh food compartment.
Apr 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
631 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
