Question about GE Profile PSS26NGS Side by Side Refrigerator
Has stopped cooling
Ref has stopped cooling 14 years old
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
IF THE FREZERWORKS THE ISSUE IS THE SETING FOR THE AIRFLOW BETWEEN THE FREEZER AND REFER BOX IS SET TO MAX COLD FREEZER, IT HAPPENS MORE THAN YOU WOULD THINK! IF IT SEEMS WARM, RATHER THAN SETTING THE THERMOSTAT TO COLDER THEY ALSO PEG THE OTHER CONTROL THAT DOES NOT CONTROL THE COMPRESSOR AT ALL IT SIMPLY OPENS A FLAPPER TRAP DOOR AJAR OR WIDE OPEN OR IF SET TO MAX COLD IT CLOSES OFF THE REEFER!! AND KEEPS THE COLD IN THE FREEZER BOX, IF THE FREEZER WORKS ITS FINE !
Posted on Apr 24, 2010
My Briggs and Stratton 14 hp lawn mower engine stops after several minutes. Cools off for a while then starts. 14 years old. Good plugs and fuel.
The ignition module is likely going bad. It is located next to the flywheel under the shroud. Follow the spark plug wire and you will find it. You can use a business card to set the gap between the module and the flywheel.
Sep 19, 2011 | Garden
My kenmore refrigerator is leaking water from the freezer to the bottom part of the refrigerator what can be the problem It is only 5 years old
it is normal if your ref. was in defrosting time then after it is in good cooling your going to do is to clean the drain of your ref. to avoid dripping of water to flooring.
Mar 04, 2011 | Kenmore Refrigerators
My Garmin will not take a charge. How can i open it up to see if I can replace the internal battery? It is about 1 yr old
If it is only a year old it should be covered by a 2 year warranty in europe (not sure about usa).
battery available from :-
http://www.amazon.co.uk/Garmin-Battery-205WT-255WT-260WT/dp/B003XUU6DK/ref=sr_1_14?s=electronics&ie=UTF8&qid=1297617680&sr=1-14
only £9
Please dont forget to vote if this answer was helpful
Many thanks
Feb 13, 2011 | Garmin nuvi 205 GPS Receiver
I have a honeywell furnace about 14 years old. The igniter just stopped working. Where do I find a igniter?
Hello, you can purchase a igniter at any heating and cooling store. they usually range between 20= 30 dollars.
Feb 03, 2011 | Honeywell Heating & Cooling
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My subzero fridge no longer seems to be cooling, its only 4 years old. Ive checked all the obvious stuff, do u have any suggestions?
Is unit running? Need to know if condenser fan (by compressor), ref fan, and compressor (the one on the right if this is a ref/frzr unit) are running.
Nov 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
GE Profile PSS26NGS Side by Side Refrigerator Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
