Question about Frigidaire Professional Side By Side Refrigerator w/ Stainless Look Cabinet 26 Cu.Ft. PLHS69EESB
The refrigerator's cooling system won't come back on
We lost power and after the power came back on light bulb and fan are on but not the cooling system...The book says to press and hold the on/off button for 3 seconds on the control panel. That does not bring it back on.
    Scholar:
  • 126 Answers
IF YOU HAVE AN ENERGY SAVER DEVICE PLUGGED IN WITH THE REFRIGERATOR THEN REMOVE IT. IF NOT YOU HAVE A BAD COMPRESSOR $ 800 TOREPAIR. THERE MAY BE A FULL FIVE YEAR WARRANTY ON THIS PART.
Posted on Apr 24, 2010
How do I determine if need refrigerant? Compressor is running hot and 2nd thermal protector has to be bypassed
More than likely one of your external coil cooling fans is not operating. OR Access for the fan to blow cooling air is blocked, or the cooling coil is so dirty the fan air is not effective in cooling the coil. Refrigerators are a sealed system. If the compressor has gotten so hot that the motor has burned you might as well find a lightly used replacement. It will probably be less than a repair by a qualified technician. Even if I told you how to replace the refrigerant the stores would not sell it to you. This is not a car Air conditioner! If you lost refrigerant it has probably burned the compressor motor. The refrigerant "acts" like a cooling system for the compressor motor.
Mar 07, 2015 | Danby Designer DAR440W / DAR440BL Compact...
Fghn2844lh not cooling
You said the freezer is working fine, so that would rule out compressor failure. If the fan motor is working on the system, check the vents and make sure they are not blocked. Sometimes, food will be placed in fron of the vents inside the freezer and inside the refrigerator compartment, blocking the exchange of air. If vents are not obstructed it may be the circuit board that controls or regulates the temperature for the refrigerator side. If your unit has a control setting, turn it off for a few minutes, this will allow it to re-set, then turn it back on and re-set the temperature settings if they don't go back to factory pre-set. Most units are pre-set at the factory for economy, but the consumer can set them lower or higher manually for more desired settings. If it is the control, you can usually replace it yourself with a new part and save money, or have a service tech do it. A power surge or power failure could have disrupted the system and caused the original factor settings to be lost, and they need to be reset. Hope that helps.
Apr 13, 2014 | Frigidaire FGHB2844LF French Door...
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Oct 29, 2006 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire Professional Side By Side Refrigerator w/ Stainless Look Cabinet 26 Cu.Ft. PLHS69EESB Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
