Question about Humax DRT800 TiVo Video Recorder
We recently bought a humax freeview & it worked fine for a month. Now it seems to lose all but one channels & needs switching off &a retune to get the channels back. What is happening please, any ideas? Does the power need to be left on
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
Humax cable and Channel connections
see the connections:God bless you
Jul 16, 2012 | Humax Televison & Video
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
How do i retune for channel 5
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Sep 30, 2009 | Humax 19 in. LCD TV
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Tuning problem
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 02, 2007 | Acer AT3705-MGW 37 in. LCD Television
Humax DRT800 TiVo Video Recorder Logo
196 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
