Question about Genie Company Genie Excelerator Down Limit Switch Part 33950s
Cant get the 2 light bulb on my genie excelerator lights up during opening and closing the garage door. what can be the problem???Please help me..
    Scholar:
  • 143 Answers
If both will not light then you will need to replace the logic board because it is very unlikely both of them have failed at the same time. If it is one, make sure the lead at the bottom of the socket is pulled far enough up to make contact with the bulb, you can replace the socket itself as well. Parts can be ordered at genie.com.
Posted on Sep 05, 2010
Genie garage door opener wont do anything. I just bought it today
Press learn on the ceiling mounted opener point the remote at the opener then press open three times then a light should blink test by pressing open if this does not work you should take it back to where you got it then ask for a refund
Nov 24, 2013 | Building Materials
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
My friend has a bad Genie garage door opener down limit switch (Door goes down and right back up again). Limit switch is made by Tane with part No.'s on it: FM-102BR-138 and 33969B. Would Limit Switch...
This is the close limit sensor so yes it should work. They have them for $2.40 right now from an Amazon vendor - http://www.amazon.com/Genie-Excelerator-Close-Switch-33950S/dp/B00283OBXY/ref=?ie=UTF8&m=A1CTO3U79X1RZ3
You can also buy replacement sensors as a 10 pack in case you end up needing more from here -
http://dpcdist.com/flangemountcontactandmagnetendleads.aspx
Sep 16, 2011 | Genie Company Genie Excelerator Down Limit...
My garage door opener a genie excelerator all of the sudden it will no longer reconize a remote, I have tried the reset button, and it is still not working. The light doesn't blink showing its receiving a...
The problem is that the logic board has gone bad. If you don't have a logic board 900 joules or higher on these units get some. You can get a replacement board at genie.com. Thanks BB
Aug 18, 2010 | Genie Company Genie Excelerator Down Limit...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
Garage Door stuck open
IT COULD BE THE SAFETY EYES.
ARE THEY ALIGNED? BOTH LED'S LIT?
YOU MAY HAVE A CABLE OFF OR BENT TRACK.
IS THE SENSITIVITY SET TOO LIGHT?
IF YOU CAN'T SEE A PROBLEM, I WOULD CONSIDER CALLING A PRO THEY CAN NORMALLY FIX A MINOR PROBLEM FOR UNDER $ 100.00. CALL THEM. GIVE THEM A DESCRIPTION OF YOUR PROBLEM. ANSWER A FEW QUESTIONS FOR THEM AND GET A PHONE QUOTE
HOPE THIS HELPS
Dec 24, 2009 | Genie Company Genie Excelerator Down Limit...
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
Genie Company Genie Excelerator Down Limit Switch Part 33950s Logo
438 people viewed this question
Top Genie Company Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Genie Company Electrical Supply Expert? Answer questions, earn points and help others
