Question about Sony Televison & Video
We have a Sony KV-27FB 16. A Stqndby/Timer light flashes and it turns itself off. How can we fix it? Thank you.
  • 7 more comments
  • anne_carp22 Apr 23, 2010
    KV-27FV16
    KV-27FV16, Serial 8015195
    What do you thinnk?
    I don't understand your explanation. Please explain what we should do.
    Jee had no answer for us. Red light (Standby/Timer ) flashes 2 times every theree seconds. Then it turns itself off. Please help.
    What does 2 flashes mean? What should we do?
    Now what?
    Does the tv need a repair shop or is it something we can go buy and fix ourselves?
    President:
  • 1,768 Answers
Usually this is a remote control function that someone has inadvertently press and the set will be set to that exact time at each power on.
1. check the setting on the remote for sleep or timer this is in the menu setting. You can usually set the TV for 1 to 4 hours depending on the manufacturers default settings.
Posted on Apr 23, 2010
  • 10,594 Answers
Please recheck model number of your Sony tv as KV-27FB16 seems incomplete/ incorrect.
Exact model number will be helpful to provide you proper info.
Thanks.
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Apr 23, 2010
    KV-27FV16
    OK, its 2000 model.
    How many times its red standby light blinks with 3 seconds big pause?
    It is an error code that shows problem section in tv.
    What do you thinnk?
    I just asked about standby light flashing, how many times it flash as there would be 3 seconds pause between flashes.
    Let me know does it flash 2 times, 3 times, 4 times or 5 times then three seconds pause then flash again.
    Turn On tv and count standby/ timer light blinks. it will blink may be 2, 3, 4 or 5 times then stop for 3 seconds and again start blinking.
    Count its blinks interval to interval and post here, this is error code that has info about problem section in tv.
    That is what I want to know, 2 times flashing.
    2 times flashing light shows problem with horizontal section in tv, check and replace Horizontal Out transistor Q502 on A Board that would be shorted out.
    ourselves?
    It depends, if you can replace parts/ solder in circuit board with proper tools then can replace this transistor by yourself or local tv repair shop will help you to get it replaced.
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Dec 02, 2008 | Sony KV-27S45 27" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
