Question about Epson Stylus Pro 9800 InkJet Printer
I switched out the inks for Photo Black (no longer matt Black) now I need to open the printer dialogue box and inform it: I get this message: The ink cartridge combination currently installed in the printer does not match the selected print settings. Open the Print dialog to update the settings.
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
SOURCE: ink cartridges replaced. Ink levels not registering
suck my balls
Posted on Jan 03, 2008
SOURCE: can't rotate ink cartridge to change
Read some of the other problems and answers and found out how to move the cassettes around manually.
Press a little spring loaded button beneath an oval hole to the left of the cassette removal hole with something like a key or flat screwdriver. This enables the cassettes to be moved around manually anti-clockwise until the one that needs changing is in position. Then just carefully pull it out. Push in the new cassette after rolling and rocking to ensure the toner is distributed as advised in all instructions.
This method is actually much easier that trying to do it from the software in your your PC or Mac. Don't know if it means that some things are not reset - but it worked perfectly for me. In fact once I knew how, it was the easiest cassette change I have ever done........!
Posted on Feb 29, 2008
SOURCE: Printing in just black and white
My Epsom DX8400 Produces a printed Black and white photo with a Green or Blue colour in it. Can the modern Printers print the old Black and White photo's?
Posted on Feb 28, 2010
nonontech
  • 4737 Answers
SOURCE: Dear Sir, Photo printer wizard will
There are mainly three possibilities causing this issue.
1. Ram i.e. Memory
2. Connection between the Printer and the Computer.
3. Spooler.
First of all, try to print the pictures using a Pdf Printer, i.e. PDF Creator or similar applications. This will help us find out if there's Ram (memory) issue. Download and install this (Click Here), open the link and click "Download Now!" button. This application is called "PDF Creator". It's not actually a program, but a Virtual Printer which prints documents as Pdf files. [If you have other similar application, you need not to download this.] Once it's installed, it should show up as printer "PDFCreator" in the "Printers and Faxes" folder. Run the windows "Photo Printing Wizard", select all the pictures of the album and select the PDFCreator as printer, you'll be prompted to save the file somewhere, save it on the desktop, it should run the process several or few minutes depending on the number of photos/documents. Do this several times and make sure there's no error or problem, if there's problem, then I would recommend you to install additional or another Ram and try again.
But if there's no problem printing this way, then Uninstall and Reinstall the printer's drivers and softwares. You may need to restart your computer for the changes to take effect. After this is done, try printing the photos again, but first as Pdf file as mentioned above not directly to the printer, otherwise you'll loose Ink and Papers.
I would also recommend you to try with another Cable, i.e. printer's USB cable.
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
Posted on Dec 07, 2010
How can I change/add a custom page set up in Epson L850?
You would change it in the print dialogue box when you are printing if it is a Custom Size. The default is set in Control Panel - Printer - Settings and would be A4 or Letter.
Printing Photo Sizes is done from the print dialogue box from the program you are printing from. Also what type of paper you are using.
https://www.google.ca/search?q=Epson+L850+printer
L850 - Epson
https://www.epson.eu/products/printers/inkjet-printers/consumer/l850
Easily print Epson-quality and low-cost photos from memory cards or directly from cameras using PictBridge with this A4 ITS photo printer. Ideal for photographers using these printers at events or in a studio, the L850 delivers reliable and high-quality photo printing together with more advanced functions such as a scanner, ...
‎View gallery · ‎Tech Specs · ‎Ink and accessories · ‎Support
Epson L850 Photo All-in-One Ink Tank Printer | Ink Tank System ...
https://www.epson.co.in/For.../Printers/...Printers/Epson-L850...Printer/.../C11CE3150...
Rating: 3.7 - ‎7 reviews
Imaging enthusiasts and professionals can look forward to the 6-colour ink tank system, presenting vibrant borderless prints and unrivalled performance at a remarkably low cost through this 3-in-1 photo printer. ... Epson’s proven original ink tank system delivers reliable printing ...
Epson L850 Review & Photo Quality Test - YouTube
Video for Epson L850 printer
? 16:48
https://www.youtube.com/watch?v=xsbxyfMogw4
Jun 9, 2015 - Uploaded by The Tech Bulletin
This video shows an In-Depth review of Epson L850 along with the photo quality test. Priced at $400, Epson ...
Epson L850 Specs - CNET
https://www.cnet.com/products/epson-l850-multifunction-printer-color/specs/
Printer. Inkjet Technology. Epson Micro Piezo. Minimum Ink Droplet Size. 1.5 pl. Ink Cartridge Configuration. 6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan). Direct Printing Specifications. PictBridge ...
Mar 24, 2018 | Epson Office Equipment & Supplies
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
Epson stylus pro 9600 error command
Sounds like you have to change the black ink from photo black to matt black
Oct 06, 2017 | Epson Stylus Office Equipment & Supplies
Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot print
Change the cartridge ...
but, in case E3
- place it in
- start the printer
- print something
Mar 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Epson 4800 won't initialize after changing black cartridge
Did you change from matte black to photo black? Or vice versa? If so you have to use the ink conversion kit that came with your printer and draw out the old ink and install the new black in cartridge. Try page 113 in your owners manual. I am having a similar problem but with the light cyan and it says "set ink cartridge".
Feb 03, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson R2880 trying to change matt black to photo black
There are many solutions posted already - what I do is in photoshop i start to print - even though I cant select the paper I want because the wrong ink is recorded - and I click print preview... then click print. The epson drivers tries to print, THEN detects the NEW ink and sends me back to selecting the paper with the new ink properly sensed. I hope this helps.
Keith
Feb 01, 2009 | Epson R2880 InkJet Photo Printer
Printing paper choices
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Aug 19, 2008 | Epson Stylus 2200 InkJet Photo Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
