Question about Philips Magnavox DVD/VCR Dual Player
Philips dvdr 3320 v DVD Player Unlock region codes
I can play some dvd s, but not others the worning wrrong area codes wrrong area code appears with legal pre recorded movies, can you help?
philips dvdr 3320 v DVD Player Unlock region codes?
Regards Jose
email: charterstowers@hotmail.com
  • kcpeter Jan 24, 2009
    Error in area code
  • Anonymous Mar 30, 2014
    Unlock region code
  • 376 Answers
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
My philips dvd hts 3545 does not play the dvd says there is no disk. it could be a problem of region code. how can i unlock the region code to make all region code
hi,
you can make the player region free by the following setup.
1.TURN ON THE PLAYER
2.PRESS OPEN/CLOSE TO OPEN THE TRAY
3.WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6 in sequence
4.YOUR REGION AREA WILL BE DISPLAYED.
5.PRESS "0" TO UNLOCK ALL
6.PRESS "OK"
ok
Jan 26, 2011 | Philips Televison & Video
Change area code of device please
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
May 23, 2009 | Philips DVD963SA DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Code required please
hello .
try this region codes for the region codes . for philips dvdr 3380.
riz.
Feb 09, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd player
Just google a bit like
"My brand nad type" region code unlock
You can be surprised - once it was - press 999 on remote :)
Dec 04, 2007 | Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
1,638 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
