Question about Microsoft Metrologic MS3580 QuantumT Barcode Scanner - P/N MK3580-32B47 Barcode Scanner
I have a Metrologic MS3580 QuantumT Barcode Scanner and as soon as I plug it in (USB) it beeps then makes a loud buzzing sound. It does not scan anymore. Does anyone know if there is something I can do or is it in need of repair? Thanks.
3 Suggested Answers
penmobile
SOURCE: Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Mar 20, 2009
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
Hello Is there any driver for use this scanner with usb port?. Thanks.
Please go the Honeywell site listed below (as they are the parent company of Metrologic).
The link should take you directly to the software downloads pages for the Metrologic MS3580. The software you are looking for is Honeywell Scanning and Mobility USB Serial Driver...it is 4mb in size.
Please follow directions carefully during installation as these scanners are a little finicky on driver installation.
Please click HERE for the link to the website and then click "software" to be taken to the drivers page.
Hope this helps.
Thanks,
May 09, 2011 | Metrologic Instruments Metrologic MS3580...
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner beeps. Laser is a dot instead of a line.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Ms9520 buzzez and then will not scan
Look at your user's guide on Pg 14, here is a online link for it: http://lib.store.yahoo.net/lib/barcodescannersdiscount/MetrologicVoyagerUG.pdf "Continuous Razzberry Tone with all LEDs off: If, upon power, the scanner emits a continuous razzberry tone, then the scanner has an experienced an electronic failure. Return the unit for repair to an authorized service center." Is the "Razzberry Tone" the low buzzing you refer to(?) Pg 24 has a "Trouble Shooting Guide" take a look at it too.
Jun 06, 2007 | Metrologic Instruments METROLOGIC VOYAGER...
Microsoft Metrologic MS3580 QuantumT Barcode Scanner - P/N MK3580-32B47 Barcode Scanner Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
