Question about Whirlpool Dryers
Hi i have a whirlpool gas dryer LGR8648LWO and
Hi i have a whirlpool gas dryer LGR8648LWO and there was a paper clogg in vent i cleaned it out and and i have replaced the high limit thermastat when i first turn on dryer the heat glow comes ignites a flame then stays lit for ten min turns off then the glow comes back but it does not reignite and then i smaell gas i do have a thermal fuse but if i install it i cant return it can you tell me should i replace thermal fuse or what else before that? ty
    President:
  • 949 Answers
If your ignitor (glow bar) is glowing that indicates the thermal fuse is okay.
With the symptoms you are describing it is acting more like an air flow issue than a component failure. Make sure your door seal is good, your venting is connected properly and try it again. I would not install the thermal fuse.
Posted on Apr 23, 2010
Testimonial: "this wasnt the problem but it was good info and i checked the seals ty"
Whirlpool lgr8648lwo squeels when running no other problems.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 10, 2011 | Whirlpool LGR8648 Gas Dryer
We are in a new house and trying to figure out how long the exhaust vents should be concerning safety fire hazard. Model # lgr8648lwo
As short as possible with no turns if possible. Ideally it would be short and stright, If possible have someone small that can climb over machine after tighting the clamps. Use a aluminum hose and snips or dikes to cut. Do not use the plastic ones they are a fire hazard and a code violation in many states.
Jul 10, 2010 | Whirlpool LGR8648L Gas Dryer
CANT FIND THERMASTAT
its behind rear panel on the blower housing
Apr 14, 2010 | Whirlpool LGR8648L Gas Dryer
I have a 29 inch 73.7cm gas dryer it won"t put out any heat to dry. everything else works fine.
check your venting for clogg/build up - other wise it is the ignitor
Nov 04, 2009 | Whirlpool Dryers
Whirlpool gas dryer heats then stops
you will want to do two things
first check you vent exhaust even a small clogg here can be detrimental
then if thats clear
repalcce the coils on the top of the gas valve
they are probaly weakening
they are called the boost and assit
or hold and assit
they sit ontop of the gas valve
Oct 13, 2009 | Kenmore 63942 Dryer
No heat after a minute of drying
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post thecoils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
May 30, 2009 | Dryers
Not drying clothes
if your dryer is heating but not drying check the flow of air coming from your vent outside if does not blow very hard you might have a clogg in the line but the best way to test it is to unhook vent from back of the dryer and dry a load but only do that if you have an electric dryer not gas your is just as important as the dryer itself
Mar 08, 2009 | Whirlpool Dryers
Dryer spins and very little heat
clean out all wall and dryer vent holes,i think you have a clogg somewhere-mike
Feb 23, 2009 | Whirlpool Dryers
Your GAS dryer has no element.
You should remove the vent from the rear of the dryer.
Run on hi heat with no laundry.
Your exhaust temperature should be from 130 to 165 degrees.
If not you have a thermostat problem or a ignitor/gas valve problem.
Feb 21, 2009 | Whirlpool LGR3624JQ Gas Dryer
New dryer does not dry clothes, cleaned vent to no avail.
make sure the vent is cleared ,sometimes all of cust / think they clean out but instead make clogg even worse,,, repl/coils remove 2 screews 1/4 in from botom panel heating coils are black in color simple fix,,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
286 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
