Question about Ricoh Aficio 220 Laser Printer
How to replace image unit ricoh aficio 220
Image unit ricoh aficio 220 must be replace.How?
  • Anonymous Mar 14, 2014
    RSS CABLE PROBLEM AFICIO 220
  • 903 Answers
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Posted on May 29, 2010
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
I'VE BEEN STRUGGLING FOR MONTHS NOW I CANNOT FIND THE WASTE TONER BOTTLE FOR NASHUA RICOH SPC232 SF
Please have a look at the attached image to see where to look inside the Ricoh printer for the waste toner bottle.
You have to remove the transfer unit before you take out the waste toner bottle, as per image.
Dec 06, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
May 09, 2009 | Ricoh Aficio 1035 Copier
Sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Jan 08, 2009 | Ricoh Aficio 2015 Copier
Lite character
THE MACHINE NEED TO BE CLEANED FROM INSIDE. SOME PARTS ARE DIRTY AND THEY DO NOT APPLY WITH THE NEEDED VOLTAGE BECAUSE OF THE DIRT.
THOSE ARE LIKE CHARGE CORONA ,LASER GLASS UNIT OR THE DRUM UNIT IS WASTED AND DO NOT ATTACH THE TONER ON GOOD.
SO IF YOU HAVE A TECHNICAL BACKGROUND YOU MAY TRY OPEN THE MACHINE AND CLEAN THE MACHINE WITH VACUM CLEANER AND CORONA CHARGE WITH ALCOHOL BUT BE CAREFUL TO NOT TOUCH THE DRUM OR SCRATCH HIM OR CLEAN WITH SOMETHING YOU CAN ONLY WIPE THE DRUM WITH SOFT PICE OF CLOTHE
Nov 20, 2008 | Ricoh Aficio 220 Laser Printer
My Rico Aficio 200
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Aug 27, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 220 Laser Printer Problem not printing
This is an error related to the laser unit.
Switch off the machine.
Please replace the Polygon mirror motor situated in the laser unit.
Part number AX06-0181.
Good luck and please rate me.
May 14, 2008 | Ricoh Aficio 220 Laser Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
570 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
