Question about Kenmore Washing Machines
I have model # 110.16512690 and water is dripping in into the tub from the top underneath and it is getting worse
    President:
  • 1,937 Answers
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.16512690&pathTaken=partSearch
Look at the section for the "Rear Panel".
It sounds like a leaking "Water Inlet Valve".
See the following Whirlpool / Kenmore Service Manual for these washers with a component testing section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to access the console, remove the cabinet and get access to the rear panel.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=4d62f2601c82e70e43ff0ef2f0787361
The "Manufacturer Authorized Substitution" numbers are Whirlpool numbers, meaning that you can likely get a replacement valve at many local appliance repair parts stores as well as from Sears.
Posted on Apr 23, 2010
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
I have a Kenmore series 80 Model 110 washer that drips inot the tub after the cycle. It's not a problem if I get the clothes out immediately. The leak seems to be getting worse. Any ideas on a solution?
Replace the water inlet valve on the back where the water hoses connect to the washer. It isn't sealing good. You may have to remove the top to access it.
Aug 16, 2010 | Kenmore Washing Machines
I have a Model GSL9365EQ2. It has a slow drip
Take the drain hose out of the regular drain and lower it to gravity drain into a bucket, pan, or floor drain if available. Turning the water off should not have prevented the machine from starting. The drip is likely coming from a leaking solenoid water valve at the rear of the machine where the hoses connect. Replace the valve assembly after removing the cabinet top and maybe the cabinet back panel. Make sure to remove the power if you are going to do the work. Hope this helps!
Mar 26, 2010 | Washing Machines
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Fisher & Paykel GWL08 top load washer appears a crack in the inside water dispenser
With the lid open, you'll see two white plastic plugs on the top front lip of machine. Pry them up with fingernail to reveal screws to remove. Take care not to let top flop back as plastic tabs may break.
May 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Washing Machines Logo
143 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
