Question about Car Audio & Video
Need installation wiring diagram for CDE-7830. I believe yellow is power. There is also a smaller red wire. Do not know where it goes. thanks.
  • 175 Answers
If you dont know this you should be leaving it for a proffesional as you could do damage to your car and end up costing you more then to get it fitted
Posted on Apr 27, 2010
Replacing motor on my ruud furance
you should have a wiring diagram on the top of the motor to tell you what each wire does. compare both motors and see where the wiring goes.
Nov 08, 2014 | Heating & Cooling
Starter wires
robert place large thick red /main cable onto big threaded terminal on solenoid of starter ,the smaller wire woukld atttach to the smaller terminal ..........im not sure of the snap terminal
Jan 14, 2014 | 1996 Pontiac Grand Am
I need to what are the red ,yellow ,orange,blue,&blue/white wires are on my alpine cde 9852
red Acc yellow 12volt blue power attn blue white remote turn on orange is not needed www,geeksquadkieran@yahoo.com plz e mail me if needing more info
Jun 30, 2010 | Alpine CDE-9852 CD Player
Constant power supply
next time by the wire harness that plugs it into the factory wire plugs never cut the factory plugs off you have wired something wrong you may damage something or start your truck on fire.
Apr 04, 2010 | Alpine CDE-9845 CD Player
I install a radio it dont keep a memory
Pull the radio back out. I bet you hooked up both power wires (red and orange or yellow) to the ignition on hot wire. Orange or yellow depending on the radio usualy goes to the ignition on hot wire and red to a constant hot wire. Check the radio wiring diagram or list. One of the power wires has to go to a full time power source. check the wires with a circuit tester with the key off till you find the constant hot wire (battery power)
Dec 17, 2009 | Kenwood KDC-MP228 CD Player
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
CDE-9852 turns off when driving
check your power wire (big yellow wire), your ignition wire (red) your ground wire (black) to the deck it could be a loose connection due to vibration or corrosion
hope this helps
Mar 31, 2008 | Alpine CDE-9852 CD Player
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
