Question about HP w19 19" LCD Monitor
Monitor says no signal when computer is on.
Ok so my monitor has a red LED light which means its on. when i turn on the comp it just makes a fan noise and the monitor says "no signal". all the plugs are in right, so whats the problem? plz help!!
  • 11,361 Answers
It can be the monitor, bad VGA cable (check both ends of the connector's pins), the video card in the PC (try reseating the card or the memory). Try this monitor on other PC first or try another monitor with this PC. We need to narrow down the problem first. Please post back.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 24, 2010
How do I get my computer to turn on it is saying no signal?
1st, it is the monitor that says, "No Signal." That being; is the actual computer turned on?
If it has a green / red power light and you can hear the hard drive and fan running inside the computer case, then check the cable that runs from the back of your monitor to the back of your computer's case.
It may be disconnected of just bad.
If you cannot hear any noise inside the computer case or there is no power light on, then check the electrical cord in back of the computer's case to the wall. If that is good, check to see if there is a light switch that turns that socket on and off.
Jun 02, 2015 | Computers & Internet
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
Monitor was in standby mode, computer was on. Now it shows no signal and when we try using the menu button (2) it flashes white, black, red, green, blue then a teal color.
the monitor is not receiving a signal from the computer which is why the multi coloured bars are showing. Ensure the lead is connected and is connected to the correct port of your computer. If it is connected correctly then either your graphics card is faulty or the lead, or monitor is
Apr 03, 2011 | Computers & Internet
I have a 24in wide lcd monitor for my computer and
mcdevito75 here, The red power light usually means the monitor is off, if when you press the red button it turns to green, or blue then the red power button means the monitor was off. Your monitor could be burned out.
Jul 16, 2010 | Computers & Internet
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
The light is always yellow and the monitor wont turn on
Yellow led light means the monitor is in 'sleep' mode. There is no signal being sent from whatever it's connected to. If it's a computer, try checking the connection(s), make sure it's not come lose inside the computer, try if you can the computer on a different monitor or the monitor on a different computer.
Nov 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
HP w19 19" LCD Monitor Logo
117 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
