Question about Thermador MBBS Microwave Oven
Wire burning smell from Microware
When use some kind of burn wire smell come from the back of the Microwave; any idea what might cause it. Other then that the unit works fine. I can smell it when the unit is on, with or without any food inside.
Unplug it.....if on fire, use dry chen extinguisher, if still persistent, dial 911 n get out of the house
Posted on Apr 23, 2010
My microwave was smelling like electrical wire burning specially when I was heating liquids in it. Suddenly it completely went off... Is it fixable or I should change it?
If you smelled burning electrical wire, I would definitely replace the unit.
An attempt to repair would probably cost way more than a new microwave!
Nov 02, 2017 | In Microwave Ovens
We have a GE profile microwave with inverter tech that will come on for about 5 seconds then shut off. Unplug it and plug it back in it does the same thing. It lets off a terrible smell almost like a...
Remove vent grille, then remove control panel. Check wire to cavity thermostat. Sometime wire bundle and small space causes poor terminal connections on this thermostat and will burn wire terminal. Cut off bad part of the wire, install a small terminal end, reconnect to thermostat. If thermostat is destroyed, also replace thermostat.
Aug 13, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
My ge jvm1653 BD 001 has a burning wire smell
The power supply is overheating and needs to be checked asp, this is a fire hazart and a safety issue.
May 18, 2012 | GE JVM1653 Microwave Oven
Smells like its burning
check to be sure there is no metal objects bc this causes microwaves to reflect back to the magnetron causes sparks and burning smells in the microwave nd check that all food that may have spilled is cleaned up
Feb 05, 2011 | Emerson Microwave Ovens
My microwave is not heating and I smell wire
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkllkj
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Burning wire smell
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
Nov 20, 2008 | LG Microwave
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Thermador MBBS Microwave Oven Logo
339 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
