Question about Zanussi ZWF1430W Front Load Washer
Zannussi jetsystem 1200: It won't drain? If I take the washing out and then try it does?!
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: the drier won't heat up and it flashes up a number
Have you fixed the problem yet? And if yes, how??
I have the same washing machine with the same problem. So I hope you can help me!
Best regards,
Nourah van Leeuwen
Posted on Mar 07, 2010
miket756
  • 2702 Answers
SOURCE: my zanussi jetsystem timeline 1600
there is a program fault on the bord,,,
Posted on Aug 30, 2010
SOURCE: My Zanussi Jetsystem Timeline washer/dryer
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Posted on Mar 04, 2011
The drier won't heat up and it flashes up a number (I'll check tonight again what the number is). it washes fine but won't dry. It is a Zanussi Jetsystem Turbodry 1200.
Best regards,
Nourah van Leeuwen
Jul 22, 2009 | Washing Machines
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
Jan 19, 2008 | Washing Machines
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
42 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
