Question about Magic Chef CYE3005AYW Electric Dryer
No power (electricity) is getting to the machine.
Stopped working. It's as if it is unplugged. I turned the machine off, unplugged it, shut it off at the breaker too. Turned all three back on & it worked again for about 5 minutes. But now, it's off again...
  • Philip May 11, 2010
    It would either be a poor wire connection (usually at the terminal block where the cord attaches) or a bad motor that is overheating and shutting down. The motor is part number 2200376 and runs about $140.00.
    President:
  • 949 Answers
Posted on Apr 24, 2010
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Burning smell
Sounds like the motor has gone. If this is the case, its time for a new one.
Dec 27, 2013 | Indesit IS70C Electric Dryer
Compressor Works for a while Only On Initial Plug-in
If your machine is equipped with a humidistat it could be faulty and not sensing the humidity level accurately.
Mar 05, 2017 | Danby Premiere DDR5009REE 50 Pint Capacity...
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    Washer has no power (will not turn on).
    Hi and welcome to FixYA!
    Sandy you might have a blown control board, but it may have been caused by a leaky pump. With the machine empty and unplugged, have your hubby tip the washer back and look up underneath the machine and check the water pump for signs of leakage. It is an electric pump and sometimes if the leak is bad enough, it will short out the coil in the pump and that can cause the control to shut down too. Sometimes all that is needed is to replace the pump but oftentimes the control board is taken out along with the pump.
    That wahswer has a 2-year parts and labor warranty. If it's over 2 years old, you can get a service manual and any parts you may need here:
    http://fisherpaykelparts.net/
    I hope this helps you and good luck in getting this issue with your washer resolved.
    Dec 20, 2008 | Fisher Paykel EcoSmart GWL15
    Code
    The PF stand for Power Failure. When you unplugged it, it truely did have a power failure..
    Nov 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
    T.V. shuts off
    try unplugging it from the wall for a day
    I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
    Jan 06, 2008 | Panasonic PV-C1321 13 in. TV/VCR Combo
    Magic Chef CYE3005AYW Electric Dryer Logo
    66 people viewed this question
    Top Magic Chef Dryers Experts
    Tim Whalen
    Wayne Fellows
    Wayne Fellows
    Craig Butler
    Craig Butler
    Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
