Question about Dell S2409W LCD Monitor
My computer display screen starts with the message "current input timing isn't supported by monitor display. please change your input timing to 1920x1080@60hz or any other monitor listed timing per the monitor specifications." how do i fix this?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
This works for me. I have Philips 220E
my computer display screen starts with the message - computer-display-screen-starts-message-boxnvi22znfbcuwwpqrfpfxu-4-0.png
Posted on May 28, 2015
  • 11,361 Answers
You need to set your PC video resolution to this monitor resolution, which is 1920x1080@60hz. You can do it by bootup in safe mode (hit f8 key while booting up), then select boot with VGA, once bootup, set the new resolution 1920x1080@60hz or something lower such as 1280x768 for now, reboot in regular mode, and reset resolution to 1920x1080@60hz. You may have to install driver if the 1920x1080@60hz does not show up in the list.
Posted on Apr 24, 2010
I am using FRONTECH LCD TV tuner MODEL NO:-JIL-0622.Recently connected to my new DELL LED then i was just changing the configuration of screen resolution but somewhere in middle it got stuck later on the...
update your driver of tv tuner for os of your computer.like win7 or win8.
second do windows update for your computer and do update for your graphic card--and do update bios of your computer.
thanks
Jul 14, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Gateway lcd monitor goes off and on!
First, check to make sure the input selection switch isn't stuck, after unplugging the monitor power cable. It sometimes can get stuck, or just become damaged.
If this isn't it, maybe it's time for a new monitor.
Feb 14, 2012 | Gateway FPD1975W 19" LCD Monitor
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
I am testing my system with the diagnostic program, and now I am stuck with the message "The current timing is not supported by the monitor display. Please change your input timing to 1920x1080@60 Hz...
Right click on a blank area of the destop screen and select properties from the menu that pops up, adjust your monitor settings and refresh rate to that suggested and see if it helps. dont worry if you press something wrong and cant see properly, just dont press anything and the settings will revert back after 15 seconds.
John
Dec 02, 2010 | Dell Inspiron 530s Desktop Computer...
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Monitor displays the message "INPUT NOT SUPPORTED"
Hi
please install the monitor driver to your pc the see what,...
Thanks!
Jul 08, 2009 | Acer AL1913 19" LCD Monitor
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Dell S2409W LCD Monitor Logo
1,371 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
