Question about Toshiba Satellite P30 P35 Series Notebook
Display problem my toshiba l30 laptop display is getting bright and dim while working what have to do
  • 99 Answers
Wiggle the power wire slightly. Sometimes if the connection is loose it may cause the computer to go from battery power to ac power.
If that doesn't work, could be a loose connection in screen or a part is failing. Would take to a local repair center to check out.
Posted on Mar 23, 2008
Looking for toshiba satellite l30 psl30l 00m017 driver
Try downloading from this website
http://www.driveridentifier.com/scan/desktop.php?scanid=7385910478B34ECAB736AFCF52EE90B4&pcname=TOSHIBA+%2F+Satellite+L30+++++++++++++++++++++(PSL30L-00M017)+drivers
Feb 06, 2013 | Computers & Internet
I have toshiba satellite L30-113 note book i wan vga drivers to down load from net. I have tried but coudn"t get
Hi, 1)Go to the below link. http://www.toshiba-india.com/laptop/DriversDetails.aspx 2)Under Product List, select Notebook Computers 3)Under series , select Satellite 4)Under Model select L30 5)Choose the type of OS 6)Under category select Display to download the VGA driver. 7)Good Luck
Nov 29, 2010 | Computers & Internet
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
I am loking for sound and wireless drivers for my
try the drivers for l30 (psl30)
should work search here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Jun 14, 2009 | Toshiba Computers & Internet
Drivers for Satellite L30 Toshiba
need the drivers for Model Satellite L30 Toshiba.Full Drivers Vedio,Audio Display,DVD
Feb 16, 2009 | Computers & Internet
Toshiba satellite L30 PLS30L-00M00D
Please go to the below link and select the type of operating system you are using and download the drivers. Hopefully it should work.
"http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=EU"
Thank you..
Sep 10, 2008 | Toshiba Satellite P30 P35 Series Notebook
Sound driver
Hi, I want to install sound driver on my laptptop model: Toshiba satellite L30. Please advise me.
Aug 10, 2008 | Toshiba Satellite L20-S310TD Notebook
Display is very dark
Dim screen is usually caused by a bad inverter board especially if you get video to external monitor. Usually cost $100-$200 depending on laptop.
Hope this helps!
Jun 11, 2008 | Toshiba Satellite M45-S331 Notebook
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Toshiba Satellite P30 P35 Series Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
