Question about Samsung HP-R4272 42 in. Plasma HDTV
The problem started with upper 1/3 of screen getting white bands then no picture at all not even menu still have sound.
  • BigBob Apr 23, 2010
    Thank you for your response/ are these boards identified when I remove the back? If not how do I identify them? What is the best way to discharge the High Voltage prior to working on it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the X and Y sustain buffer boards. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged capacitors on these boards and replace whichever has gone bad. If still the issue is not resolved, then please check the power supply board. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment further assistance.
Thanks
Rylee
Posted on Apr 23, 2010
  • Rylee Smith
    Rylee Smith Apr 23, 2010
    Turn
    off and unplug the TV for at least 1 hour (this will drain off
    current from all components especially capacitors) before you perform any
    repairs. Please check this picture to locate the boards:
    Please do
    accept the solution if the issue is resolved or else revert for further
    assistance.
    Thanks
    Rylee
White screen
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2015 | LG Televison & Video
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Green and purple band of color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Setup wizard
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Oct 31, 2008 | Sony Ericsson Z525a Cellular Phone
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
White bands appearing across pictures
Mikrofiber towel and a few drops of wather.
Clean the lense even if looks clean.
Try to reset the camera in the menu to the factory settings.
If not help service only.
Nov 11, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Fixed white block on the top title bar
This is clearly a hardware fault in the actual lcd display or the connector to the mainboard. the stylus function are controlled by the touchpad, it is mounted separated from the actual lcd display (on top of it) and connected with another set of wires to the mainboard. Most probably your problem can't be solved. However, try to take it to a service to have it checked, especially the connectors between the lcd and mainboard.
Dec 27, 2006 | ViewSonic V37 Pocket PC
Open Questions:
See all Samsung HP-R4272 42 in. Plasma HDTV Questions
Samsung HP-R4272 42 in. Plasma HDTV Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
