Question about Bose Wave Radio
Wave Radio-dial face,display very dim.
I have the Wave Radio AWR1-1W and it has worked fine for many years.
Now the face dial is very dim and can not adjust brightness.
Any ideas?
Thanks, Julio
  • 1 more comment
  • FrankfurtLad Apr 20, 2008
    Funny, this is exactly what happened to my wave radio a couple days ago. Didn't do anything, except that we had a power out in the early morning, which had happened before without any effect on the dimness level of the display.
    Now when the room light is turned on the display gets dimmer and when the light is off the display is brighter. Just the opposite of what it should be.
    Thanks for any advice. And no, I do not want the new wave radio. I like my two alarms and being able to use the functions without the remote.
  • waflestomp Apr 25, 2008
    My power went out and the clock dimmer seems to do the opposite also. I am currently experimenting with the CD button used at the same time as the volume control. But I won't know what effect is had until later tonight.
  • kampkos104
    kampkos104 Sep 29, 2012
    My display would work whenever it felt like changing. This problem started after a prolonged blackout. I unplugged the radio, and battery for a few minutes. It now appears to be working normal.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Posted on Oct 29, 2008
  • Intwy Dumaela
    Intwy Dumaela Jan 11, 2014
    yep, that did it, thank you.
  • Gigi
    Gigi Dec 18, 2016
    This did not work for me. Any other suggestions?
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Posted on May 14, 2008
  • jan82834 Jun 12, 2011
    We have 2 bose radios and we love them. When the electricity goes out it must reset the bose radios. I couldnt figure out how to make the channels brighter and this really helped. Thank You. Oh I was using the remote to turn the volume up and down. You cant do that, you have to use the base unit it self.. Just a little tip. Thanks again.
  • swal257
    swal257 Jul 27, 2012
    I have had this problem for some time and finally reached the pint of saying "I need to fix this darn thing". Woohoo it worked like magic. I live in FL so power outages are very common. Thank you so much!
Unplug for a few seconds and then re-plug in bright condition. i just tried this and it worked.
Posted on Jun 27, 2012
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
Why doesnt my wave radio screen light up when the lights in theroom are on ?
That doesn't make sense does it? A few things first.... how bright are the lights in the room? Is the display of the WAVE facing the lights? The radio has a photo sensor that detects light, but for it to be effective, it has to "see" the light. It could be that you have a bad photo sensor, but I would try a few things first. 1. Make sure the light in the room is sufficiently bright. 2. Make sure the display is pointed in the direction of the light. 3. Make sure nothing is covering the photo sensor (like a piece of tape or something.... maybe a previous owner wanted to "turn off" the light". 4. If none of the above get you going, shine a flashlight at the photo sensor (a bright one). This should turn on the display. If this works (and nothing else did), that just means you ain't getting enough light to the sensor under your normal conditions and you will need to correct that underlying problem first,
May 29, 2015 | Bose Wave Radio
Why does my screen go dark when I am making a call
It should go dark when you put throne up to your face. That keeps it from getting to warm on your face. If you don't want it to go dark, you can turn the auto dim off in settings under display. It will use more battery, but it shouldn't go dim. Then that may be under another setting.
Aug 26, 2014 | Cell Phones
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Dim radio light on 2000 Mitsubishi Galant
It is possible to do either, but changing the bulb might be best...it probably is making poor contact in its socket anyway.
Jan 20, 2013 | 2000 Mitsubishi Galant
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Radio display does not work
Honda has a problem with the PCB board in the radio, See your Honda dealer for repair info. Service bulletin 04-027 says:
"In some audio units, a component failure on the PCB
(printed circuit board) could cause the audio display to
become dark or dim, and prevent the audio/HVAC
panel buttons from illuminating.
To ensure that customers have adequate warranty
coverage for this potential problem, American Honda is
increasing the warranty on the audio unit display to
7 years or 100,000 miles, whichever occurs first. For
other defects the standard 3 years or 36,000 miles
warranty applies, whichever occurs first."
Feb 15, 2009 | 2004 Honda Accord
Bose Wave Radio Logo
4,665 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
