Question about Whirlpool Duet GHW9150P Front Load Washer
How do i go about replacing the door lock? Do I have to remove the whole front of the washer?
  • patrick_gord Apr 23, 2010
    Thank you very much!! Hopefully i can do it.
    Top Expert:
  • Whirlpool Master
  • 78,267 Answers
Go to the link for a freee PDF of the manual, in that manual go to page 31 for start of lock replacement instructions.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Apr 23, 2010
How do I access the door lock mechanism to replace it?
you will have to remove the rubber around the door if not the whole m/c will have to be striped even taking the rubber of its still a faf to get at
Sep 27, 2012 | Frigidaire GLTR1670A Front Load Washer
I had an F01 code and ended up replacing the CCU Board (part # w10205849) successfully and had 1 perfect wash. But the 2nd wash didnt complete. I replaced the CCU Board a second time and it's...
Hi
If you have already replaced your CCU you need to replace the door lock mechanism. Also you're still experiencing problems, you need to re-verify your electrical connections and check the CCU.
The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
The doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 25, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Door locking problem - Kenmore Elite Washer
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Feb 24, 2010 | Kenmore Elite 45986 Front Load Washer
This is weird!!
1. Unplug washer.
Feb 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont start.
FDL error = Function Door Lock Error
1. Unplug washer.
Thanks for using FixYa -a Very Helpful Rating is appreciated for answering your FREE question.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer door isnt staying locked
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Jun 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
Elite 45986, door lock mech.
1. Unplug washer.
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Hi We have a Zanussi Turbodry and when i tried to open the door it wouldn't move and i have now broken the handle off!!! How do we open the dooe?? Thanks Lynsey
Get a thin screwdriver and poke it in between the door frame and the front of the washer where the door latches in, push hard and see if it will release that way..
If no go, then remove top of washer , and with a long screwdriver or similar try to release the door catch from inside the front of washer, you may have to lever it open, and possibly break the door lock in the process.
There really is no other way of releasing door.
You obviously will have to replace the whole door handle assy, and the door lock.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Washing Machines
44072 Kenmore Washer - Front Door Won't Lock
There is a black peg on the round housing of the washer that gets pushed in when the door is closed and the machine locks the door. If the peg gets broken (as mine did) the machine won't lock. I now use a small screw...or you can buy a replacement part for the whole mechanism.
Feb 13, 2008 | Kenmore 44072 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
