Question about Fisher Paykel EcoSmart GWL15
GWL15 starts to fill, water shuts off & water coming in slows to a trickle. Hot & Cold lights flash, machine beeps. If filled with buckets of water cycle will finish.
  • 343 Answers
A common fault with F&P machines is in the water inlet valves.It is not afvisable to exchange the hot and cold valves because they are different. The faulty valve should be replaced. . Goodluck.....Nomess
Posted on Apr 23, 2010
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
My Fisher Paykel GWL 15 will only fill if Hot wash is selected. Should I call a service technician? Thanks Glenn
Try to swap the plugs and hoses to the hot /cold solenoids see if that works the hot valve with cold water if work you need to buy a cold valve.
Jan 24, 2012 | Fisher Paykel EcoSmart GWL15
F P GWL15 Washer cold & Hot water will not fill valves stop and start rapidly then the machune beeps and shuts off
Sounds like a rotor position sensor problem and that part is fitted to the motor itself.
Sep 23, 2011 | Fisher Paykel EcoSmart GWL15
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
We have a fisher and paykel MW512AU toploader washing machine. it turn on lets you select whatever and start it's wash then does these little beeps the lights on the wash progress flash depending on where...
If it is a musical rippling sound & hot & cold lights are flashing that usually indicates it is not getting water quickly enough. You can open the lid while it is filling & look. If water is just trickling in and taps are fully open then replace the inlet valve with a new one.
Jun 26, 2017 | Fisher and Paykel Washing Machines
Fills with water and then stops and beeps and won;t continue. The hot and cold water buttons are flashing. Waterr starts trickling in and it is slowly spinning but doesn't seem to agitate
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hot water is a small trickle into the machine - warm water gives you a bit more water coming into the machine & cold water has a moderate bit of water coming into the machine. We have extremely hard...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 01, 2010 | Frigidaire FWS833A Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Fisher Paykel EcoSmart GWL15 Logo
275 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
