Question about HP DesignJet 130NR InkJet Printer
Can i print a test page from my printer if it isn't hooked to the network or a computer?
  • 779 Answers
Network printer if print test page printing normaly if print pdf or word not printing !!
The test page comes from the printer itself. If the printer is on a network you need to re-establish it on the network using its IP address. If it is a network printer on one computer, you need to redownload the software.
You should also go to Settings/Printers and make sure the machine itself is the default printer rather than some type of Windows virtual printer like 'Print to File' or 'Print to PDF', Print to Fax' or a printer that is no longer there.
Nov 18, 2015 | Office Equipment & Supplies
Printer will not communicate with the computer
1. Walk over to the printer and print a test page directly. The procedure for printing a test page will vary from model to model, so you may need to consult the user guide that came with your printer. For most network printers, you can print a test page by navigating the "Information" menu on the control panel and choosing "Print Configuration" from the menu. For many desktop printers, you can print a test page by holding the power button until the page begins to print. If you can print a test page from the printer, but not from the computer, you know there is a communication problem between the printer and the PC.
2. Remove the printer cable from the back of your printer and the back of your computer. After the cable has been removed, carefully put the cable back into place, making sure that the printer cable is tight. If your printer uses a parallel cable, be sure that it is fully seated on the back of the printer and on the computer. If you are using a USB cable for your printer, be sure that the tab is fully seated in the computer, and that the square end of the cable is firmly connected to the printer.
3. Power down the printer, the restart your computer. Click on the "Start" button and choose "Control Panel" from the menu. Double-click the "Printers and Faxes" icon, locate your printer, right-click on it and choose "Properties" from the menu. Click on the "Print Test Page" button to send a test page to your printer.
4. Look at the network card on your network printer to see if there is good communication between the printer and the network. You should see a flashing green light on the network card. If there is no light--or if the light is amber or red--the communication is not happening. To test the network communication, remove the network cable from both the network cable and the network port on the wall, then reseat the cable and check the communication again. If the problem remains, you will need to remove and replace the printer's network card.
Aug 10, 2012 | Lexmark X4650 InkJet Printer
How do you run a print test for an HP deskjet F355 all-in-one printer?
This is invoked at the printer properties and set up page. Look for print a test page.
HP printers often perform poorly if hooked up using Plug and Play. Download the latest install software directly from HP, and follow directions exactly, no plug and play. All computers need the same install for networked printer (meaning not hosted and shared).
Oct 20, 2010 | HP DeskJet F380 All-In-One Printer
Aficio 1515MF All-In-One Laser Printer: I don't know where to find my IP address on my 151...
If you're at the copier, go into User Tools, and then under System Settings there should be a Network section, and then in that Network section you should be able to find the IP address.
You can also print out a config page by going into User Tools and then Printer Settings, and selecting List/Test Print. The config page will have all of your network settings, including IP address.
If you're running Windows Vista and the 1515 is hooked up to your computer, you can view the IP address by hovering over the copier on the Network Map (from the Network and Sharing Center).
May 17, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Printer is not printing any jobss sent to it by any computers hooked up to network. Network LAN is good to go, all plugs and wires are in proper place, prints out a test page just fine. Power is on. Still...
Go to printers and fax folder and right click on your printer. Then go to properties and the click the advanced tab. Then choose the option, print directly to the printer. Click apply and close the window.
Jul 07, 2009 | HP Color LaserJet 2600n Printer
How do you setup remote
  • Automatically configure an Ethernet connection
  • Click Start and then click Network. The Network window displays.
  • Click Network and Sharing Center.
  • Verify that the network is connected to the computer. The network is connected to the computer if a red X does not display on the screen.
Figure 1: The computer is connected to the network
Figure 2: The computer is not connected to the network
Connect the printer to the network with an Ethernet connection.
  • Click Add a Printer.
  • Select the Add a network, wireless, or Bluetooth printer check box.
  • In the list that displays, select the desired printer and then click Next.
  • In the Printer Name text box, type a name for the printer.
  • If desired, click Print a Test Page to print a test page.
  • Click Finish.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
How to configure printer on wireless network
Is the printer being installed on the computer itself or is it being plugged into a print server/hub?
Nov 13, 2007 | HP Color LaserJet 2600n Printer
HP DesignJet 130NR InkJet Printer Logo
629 people viewed this question
Seeker5211
Seeker5211
