Question about Fisher and Paykel GWL11 Top Load Washer
Washer will not empty out - Fisher and Paykel GWL11 Top Load Washer
  • 343 Answers
The problem is most likely the water pump. Unplug machine and tilt back so you can see the pump on the bottom of the tub on the right front. Turn the air fan on the pump this will tell you if there is some thing jamming it. These pumps can also fail and overheat No tools required...Good luck.....Nomess
Posted on Apr 23, 2010
Washer not spinning.
IF IT IS EMPTYING THE WASHER LISTEN FOR A SWITCH TO CLICK AFTER IT HAS STOPPED BEING EMPTIED IF YOU DON'T HERE ONE THE SWITCH IS NOT WORKING AND IT WILL NOT LET IT SPIN WITH WATER STILL IN THE SYSTEM EVEN WHEN IT EMPTY AS IT THINKS IT'S STILL FULL I HOPE THIS WILL HELP YOU
Nov 05, 2014 | Washing Machines
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
Washer will not empty its water -hotpoint washer
Chec to see if the water pump is plugged with lint or some othe debris
Oct 14, 2009 | Hotpoint Washing Machines
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer continuously filling/emptying
Your drain hose from the washer is in your household drain line too far, should not be any further in the drain line than 7 inches
Mar 23, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
48 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
