No sir/maam it is not.
FixYa is a product support website, and does not manufacturer, nor sell computer parts.
We try our hardest to solve product problems.
You could replace those missing keys, or you may want to consider replacing the Keyboard itself.
http://www.laptoppartsexpert.com/i-59864-laptop-keyboard.htmlhttp://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-2.htmFollow Steps 9 through 12. You can click on the photos to enlarge.
The Keyboard Cover they state, is a Speaker Cover according to Toshiba.
(I'm looking at the Service Manual right now)
It is just a plastic cover, with no attaching wires.
Still, use care when inserting a tool to pop it up. Do not insert the tool too far.
The outside edge as shown is eased up until a built-in tang releases.
The outside edges of this plastic strip have tangs formed on the edges. They snap into a matching depressions in the Keyboard, and Top Cover.
The tang, and the matching depression is named a Latch.
There are 4 Latches across the top, and 4 Latches across the bottom.
The Speaker Cover also has formed covers which are an integral part of it, and these covers cover the Hinges.
As the Speaker Cover is eased up on one side, you'll hear a snap sound as the Latch releases.
Same thing for every latch to follow.
Just wanted to note this so you do not think you are breaking something.
(For your first time it may make the hair on the back of your neck stand up. Snap, snap, snap, as the Latches release. The Speaker Cover is made from a space age plastic.
Pretty tough stuff. It can be broken, however)
Once the Speaker Cover is removed it's time for the Keyboard.
There are two Philips head screws to remove, at the top of the Keyboard.
This is shown in Step 11's photo. (Click on it to enlarge)
Now the top of the Keyboard is lifted up a LITTLE, and slid towards the LCD screen, a LITTLE.
The Keyboard still has the Keyboard Cable attached.
The cable coming from the Keyboard is an FFC.
Flat Flex Cable.
Looks like a plastic strip with wires in it. There is NO connector on the end of the cable that goes into the motherboard. The end of the FFC that inserts into the connector on the motherboard, just has exposed contact points for each wire in the cable.
The connector on the motherboard is a ZIF connector. Zero Insertion Force.
The connector is composed of two parts, but Does NOT come completely apart.
It just opens a little bit.
The ZIF connector is a small rectangle. It has a smaller rectangular part that goes across the top. (LCD screen side)
This smaller rectangle is the only part that moves. The larger lower part of the connector is attached to the motherboard.
The top 'half' is eased up. It only moves approximately 1/8th inch.
One top corner is eased up, then the other top corner is eased up.
This action unlocks the ZIF connector, and allows the Flat Flex Cable to be removed.
Reverse these steps to reinstall the Keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
While attempting to remove top panel, I removed the zif connector from the motherboard. As a result the power button does not respond. Can the connector be reattached or is there an alternate remedy to the problem?
