Question about Measuring Tools & Sensors
Registter Black & DEcker ScrewDriver - Measuring Tools & Sensors
  • 2,841 Answers
You register your tool here: http://www.blackanddecker.com/membercenter/
Posted on Apr 24, 2010
Testimonial: "I WAS UNABLE TO REGISTER A NEW TOOL UNTIL i RECEIVED AN EXPERT TIP."
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
I need the instruction manual for a PD600 black & decker pivot plus. The black & decker website sells them but when entering the model says none found...weird
Go to the Dewalt service website at http://servicenet.dewalt.com, put your model number in the parts search box and you'll be presented with two versions of your tool. Select one and you'll be taken to a page where you can view or download the manual, parts breakdown, or order parts. There are only four replaceable parts for your tool.
Jul 01, 2012 | Black & Decker Pivot Plus Cordless...
How do you turn it on?
Click on the link below to access the Black & Decker Pivot Cordless Drill/Screwdriver owners manual, inside this manual will show you how to turn it on:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/5145342-00,PD600PD600G.pdf
Feb 04, 2011 | Black & Decker Pivot Plus Cordless...
How do I change the screw drivers on the black & decker power screw driver?
The black collar should slide forward, allowing for the removal and insertion of bits.
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
Can't remove spool from Black & Decker GH1000 weed wacker
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Sep 03, 2010 | Black & Decker 14" Grass Hog Xp...
Black & Decker Nickel Cadmimum replacement battery
Check the store where you purchased the screwdriver but you will find its cheaper to buy a new screwdriver with new batteries than to buy just the batteries.
Jul 12, 2010 | Black & Decker 9072CTN 2.4V Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
I have a pink black & decker cordless drill which I use for small household tasks. However, my husband uses this too for small jobs. My problem is the ac adapter has gotten misplaced & I need one....
Contact Black and Decker (Dewalt) at 800-235-2000-you should be able to get number for an authorized repair center that can supply it for you-but it may be cheaper to replace the whole thing.
Mar 11, 2010 | Black & Decker Pivot Plus Cordless...
NEED BLACK & DECKER MODEL KC 9036 chargeable battery in India 3 way screwdriver
It is not worth trying to get batteries for this , the whole thing costs £10 in the UK, which is less than you would get the batteries on their own.
Dec 15, 2009 | Black & Decker Drills
Measuring Tools & Sensors Logo
100 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
