Question about LG LHB977 Theater System
STUCK ON BYPASS WHEN PUSHING THE SOUND BUTTON
Pool heater 406A unitherm governor
make sure connected correctly not enough water passing through if you have a bypass close half way if no bypass check the maual bypass in heater might be damaged or stuck
Sep 15, 2014 | Pool & Spa
2004 suzuki automatic transmission stuck in park
that is park lock failure, build into the shifter section,it has an
electric solenoid lock. and a bypass button.
in the glove box, see oper. guide, it tells you where the erg. release
button location, and varies by sub body type and options.
its hidden cover, or a slot, on most cars. the slot type is to insert
any key in slot and push. bang, it opens (brake set,etc)
Dec 25, 2013 | 2004 Suzuki Verona
Bypass doser doesnt work. I put grinded coffee powder in there and hit the bypass button, then the small coffee button, The machine starts but no coffee dripped but only hot water? Did I do something...
Hi, sounds like your pushing the wrong button or doing the process in the wrong order. If your putting coffee in and only getting water, then that tells me that is is dumping the coffee before it gets brewed. dazza
Oct 08, 2011 | Gaggia Titanium Espresso Machine
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
It will not go in gear by pushing brake,or by pushing bypass button.
Gear Box needs to be replaced.
Just had the same problem for my 300c, cost about $350 a dealer
Jun 23, 2010 | 2005 Chrysler 300
How to close(broken) sunroof manually Volvo 2001 s80
i think it might be the open and close buttom has something wrong or the motor of the sunroof it is better that it is seen by a specialist
Oct 19, 2009 | 2001 Volvo S80
When pushing the start button on dryer, the motor makes loud buzzing noise and the drum doesn't turn.
I'VE HEARD THIS SONG BEFORE. WHEN PUSHING THE START BUTTON AND GETTING A AAARGH SOUND THIS INDICATES A BAD MOTOR. YOU NEED TO RULE OUT SOMETHING STUCK IN BLOWER. FILTER INSIDE DOOR, FRONT PANEL, TOP FILTER 95% MOTOR, ACCESS THROUGH BACK. HOPE THIS HELPS PLEASE CONTACT ME @ HUBAPPLIANCE@COMCAST.NET AND PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Open Questions:
FIOS TV, audio static with HDMI connection I have been having this problem for months and the only thing VZ tech support has done is send me a new STB each time and the problem still remains. I have a STB+DVR in our family room which works fine. I have a second STB with my home theater system which is having this issue (this is just an STB and not a DVR). Connections for this second STB: 1. This STB Coax out is connected to an old analog TV. This works fine, no issues. 2. The HDMI out goes to my LG DVD player **bleep** home theater system HDMI in. This is where the problem is. When I watch any FIOS program whether live or recorded on the main DVR, the video signal is fine but the audio has static and is raspy. I have done multiple reboots on the multiple STBs Verizon has sent me and hasnt solved the problem. I can watch DVDs, Netflix, Roku apps on this home theater system through HDMI and they have crystal clear audio, no issues. So I know the problem has to be with the Verizon STB. Settings and things I have tried: 1. Dynamic range = none 2. Audio = surround (have tried the others mono and stereo also) 3. Volume = fixed, variable etc no impact 4. The HDMI cables are high quality with gold connectors. I have tried multiple cables, static remains. 5. I placed the STB box on an old wooden cutting board to ensure there is no other metal contact that might lead to static 6. I connected the STB audio out components (red and white) to the audio in on my home theater system and the audio was perfect Any suggestions? It is really irritating to watch programs with audio static. There is no source of electromagnetic radiation in the vicinity other than normal ambient.
Feb 28, 2017 | LG LHB977 Theater System
See all LG LHB977 Theater System Questions
LG LHB977 Theater System Logo
234 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
