Question about Minolta Compact Binocular
Binocular Loss Of Fluid
My Minolta compact zoom lost it's fluid. Now the gears don't work. They are frozen in place. Can this problem be repaired? Thanks.
  • Noel St. John Aug 03, 2008
    My binocular are also "frozen". It is very difficult to adjust the focus. One day it was fine. The next it had this problem. I can't speak to a loss of fluid. All I know is it is difficult to adjust the focus -- much force must be used to get the center knob to move.
  • Anonymous Feb 08, 2009
    I have the compact 8x25 Minolta; it was difficult to move the focus barrel off and on for several years, and now absolutely impossible.
  • 14 Answers
I never figured out how to fix it but I bought them at REI and they were able to find the receipt and get a warranty repair. One problem is Minolta no longer makes binoculars so a service center takes care of warranties.The Minolta site has details.
Posted on Aug 28, 2010
What can cause loss of allgears in transmission
The first thing is to check if you have enough transmission fluid in it. There is a dip stick and if you don't see any fluid on the dipstick, then add one half quart at a time and see if this helps. Also, there is a transmission repair fluid that may help such as "slip stop". List Transmission Treatments Additives Reilly Auto Parts
May 09, 2014 | 1996 Chevrolet Blazer
Minolta Compact II Binoculars - the focusing adjustment is seized, how do I free it?
The adjusting knob has a rubber cover over it. Remove the rubber cover and take out the phillips head screw underneath. Then turn the adjusting knob all the way left with a pair of pliers and continue turning and it will unscrew and come off. Underneath you will find a metal lock nut, when you loosen this you will find the adjusting knob is suddenly not frozen anymore. It seems that this nut tightens over time to the point where the whole mechanism freezes. You can take the nut off and put some thread lock on the threads and tighten it just enough and it won't happen again. Cheers.
Sep 24, 2011 | Minolta Compact II Binocular
I have had to add brake fluid twice in the 7 months since I bought my 2005 Malibu. Should I be concerned?
Hi!
YES! You should be very concerned. The breaking fluid must never leak. It can happen anytime that the car loses all breaking power, by leaking more fluid and by air entering the system. Please let a professional check and repair that breaksystem.
Best regards!
Aug 08, 2011 | 2005 Chevrolet Malibu
WHEN IM DRIVING, IT POPS OR JERKS ALL OF A SUDDEN AND THEN WONT SHIFT GEARS. WHEN IM ON THE EXPRESSWAY AND IT DOES THIS, IT WILL BARELY GO 55 MPH.
Your transmission fluid is dangerously low (tranny is dry). The pops & jerks are the transmission
internal components trying not to seize onto each other due to lack of lubrication and/or overheating.
Low transmission fluid leads not only to loss of lubrication but lots of overheating (of the tranny).
The loss of Elantra performance (speed tops out at 55), is caused by power loss due to friction inside the transmission. All your power is lost overheating the transmission (toward destruction), instead of
being transmitted through the transmission to the wheels.
The 2004 Elantra takes Hyundai SP-III Automatic Transmission Fluid, with 8.4 quarts used in a
total refill - but just 5 quarts at a fluid change. For How-to transmission fluid change instructions:
http://en.allexperts.com/q/Hyundai-Repair-815/2004-Elantra-GT-transmission.htm
www.autozone.com claims that 2004 Hyundai Elantra can take these non-Hyundai ATF's:
Lucas Semi-Synthetic Multivehicle ATF
Pennzoil Muilt Vehicle ATF
Valvoline Maxlife Dex/Merc ATF
Castrol High Mileage ATF
Jan 05, 2011 | 2004 Hyundai Elantra
Check automatic transmission fluid level 2004 Pontiac grand am
TRANSAXLE FLUID CHECKING PROCEDURE
The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid.
Inspect
The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F) .
CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe.
The engine must be running when the transaxle fluid level screw is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level screw. Have a container ready to capture any lost fluid.
WARNING: Do not turn the engine off with the fluid level screw removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole.
  1. Let vehicle idle for three to five minutes with accessories off.
  2. Apply brake
  3. Move shift lever through all gear ranges, pausing three seconds in each range.
  4. Place shift lever in Park.
Important: Vehicle must be kept level on the hoist.
  1. Raise vehicle on hoist.
  2. Place oil container under fluid level screw.
  3. Remove the fluid level screw with the engine running at idle.
  4. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID.
  5. Install fluid level screw.
Tighten 12 Nm (106 lb. in.)
  1. Lower vehicle.
  2. Shut off engine.
Adding Transaxle Fluid:
With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole.
  1. Install fluid level screw.
  1. Lower vehicle.
Oct 20, 2010 | 2004 Pontiac Grand Am
The zoom lever is not working moves but doesnt change
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Feb 20, 2010 | Minolta Classic II Binocular
Minolta Compact AF 8 binocular continually focussing
My Binos are doing the same thing, I think it is some fixed mode it is stuck in. Anyone know how to get is back to normal working? Maybe the big AF button is stuck on?
Help please as I can't find my instruction manual.
Feb 07, 2010 | Minolta Compact Binocular
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
Jan 31, 2010 | Minolta Activa Pocket Binocular
No tranny dipstick to be found ANYWHERE!!!!!!!!!
The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid. Inspect The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F) . CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe. The engine must be running when the transaxle fluid level screw is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level screw. Have a container ready to capture any lost fluid. WARNING: Do not turn the engine off with the fluid level screw removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole. 1. Let vehicle idle for three to five minutes with accessories off. 2. Apply brake 3. Move shift lever through all gear ranges, pausing three seconds in each range. 4. Place shift lever in Park. Important: Vehicle must be kept level on the hoist. 5. Raise vehicle on hoist. 6. Place oil container under fluid level screw. 7. Remove the fluid level screw with the engine running at idle. 8. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID. 9. Install fluid level screw. Tighten 12 N.m (106 lb in) 10. Lower vehicle. 11. Shut off engine. Adding Transaxle Fluid: With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole. 1. Install fluid level screw. Tighten 12 N.m (106 lb in) 2. Lower vehicle.
Jun 05, 2009 | 2004 Chevrolet Malibu
Minolta Compact Binocular Logo
349 people viewed this question
Top Minolta Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Minolta Optic Expert? Answer questions, earn points and help others
