Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Replaced ice maker with new won't work
Relay switch caught fire replaced with new.fridge worked but ice maker wouldn't replaced with new still won't come on.
    Scholar:
  • 126 Answers
IF IT WILL NOT MAKE ICE YOU NEED A WATER VALVE. IF IT WILL NOT DISPENSE ICE YOU NEED A DOOR. BECAUSE THE WIRES AT THE BOTTOM OF THE DOOR BROKE. ORDER PARTRS HERE.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 24, 2010
Ice maker in not working
A lot of times the reason the ice maker is not working is 1 of 2 things. First I would check the water filter if the fridge has one, and make sure it is new, or replace it if it has been over 3 months (depending on the fridge and filter, could last longer). If you replace the filter and the ice maker is still not working, be sure to check the water line going into the fridge, if it is a plastic line (soft to the touch) make sure to squeeze it ever so gently to see if water is flowing through the line properly. If so then, you may need to turn the water off to the fridge and disconnect the water line from the fridge to see if it is clogged, if so it could be clogged with calcium deposits, if not then the mechanism for the ice maker it's self could have gone out and needs replaced. This all depends as well on how old the fridge is. If the ice maker has a metal bar, be sure it is in the proper position to make ice, a lot of times they get broken and need replaced.
Apr 08, 2014 | Refrigerators
KitchenAid KSCS23FTSS01 Ice Maker Not Working
Is it getting water? The inlet valve on the back of the fridge where the water line connects is a frequent source of ice maker problems. If the It sounds like you've covered the other major issues.
Nov 28, 2013 | KitchenAid Refrigerators
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
91 Cherokee will crank but won't fire. Replaced
how much is the RPM showing in the datatlogger while cranking?
Dec 03, 2012 | Cars & Trucks
My admiral side by side refrigerator (model #: LSD2615HEZ) is making a buzzing noise that clicks on and off periodically. It sounds like it's trying to start something and then shorts out after about...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one.
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Admiral 26 cu. ft. Side-By-Side...
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
AMANA FRIDGE SCD23VBW, NEW ICE MAKER WON'T CYCLE
repairs should be performed by an authorized repair technician. D7824706Q complete ice maker should never be advanced manually. the ice maker arm should be in the down position in order to advance. once the inner thermal switch has been satisfied the ice maker motor should advance. the ice maker is damaged and will need to be replaced by the proper ice maker.
Jun 04, 2017 | Refrigerators
Icemaker won´t work
if you got 110 volts to ice maker. try jumping out the T & H ( a small insulated copperwire) . this will cause the ice maker cycle, if this does nothing replace the ice maker.(entire assy cheaper then the parts). remeber you might have to shut the door switch to get the 110v. some machines run the power through light switch
Mar 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
77 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
