Question about Brother MFC 210C All-In-One InkJet Printer
Black will not print
Cleaned the heads many times
all other colors work fine
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
X75 My color won't work. Black is fine. I installed a new one at Xmas and it worked fine. I hardly printed anything.. Yesterday the test page with peacock showed no blue and everything came out yellow. ...
run the print head cleaner tool using the lexmark software. since you hardly used the color the print head nozzle is dried up and needs to be clean.
run the print head cleaner atleast 5-10 or more times as needed.
Mar 12, 2011 | Lexmark X75 All-In-One InkJet Printer
I have an 8-year old Canon i9100, and have just installed my third brand new Print Head. It worked fine for one month, then the black started fading and then just stopped printing. All the other colors...
It is probably a bad purge assembly, when it doesn't clean or prime the printhead properly you have the problems you are describing. There are 2 sections in the purge assembly, one cleans color and the other cleans the black. Sounds like the black pump is worn out. The part runs around $30.00
Jun 29, 2009 | Canon i9100 InkJet Photo Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Apr 21, 2009 | HP Office Equipment & Supplies
Black does not work after multiple head cleanings
It sounds like the black nozzle is clogged. I am not sure if that is a part that is end user serviceable. Best bet would be to call Epson and see if it is something you could repair or if they need to have you send the unit to them. Sorry.
Jan 10, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Wont print black but colors are fine,
Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Oct 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
230 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
