Question about HP PSC 2210 All-In-One InkJet Printer
No power will not trun on - HP PSC 2210 All-In-One InkJet Printer
    Genius:
  • 1,456 Answers
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Posted on Apr 23, 2010
My ipad will not trun on. tried hooking it up to the cumputor and hit both volume and on button at the same time but no luck.
I had this problem with my iPad mini. In search the web, it was said the output of some computers were insufficient to charge the device. I tried plugging it into a USB wall adaptor and after a few minutes, it powered up. If you do this, don't expect it to power up for a few minutes.
May 31, 2014 | Visual Land Prestige Pro 10D 16 GB Tablet...
Trun switch don't work put in new one still don't work
Turn signal, or trunk ?
Do you have power going to the switch ?
Jun 24, 2013 | 1989 Ford Taurus
How to trun the power up on my galaxy dx 55v
AM CARRIER POWER HIGH: VR-13 pot. for RF power adjust
AM CARRIER POWER LOW: VR-16 rf power adjust
Oct 22, 2012 | Galaxy Radios DX-55V Base CB Radio
Tablet will not stay on, only turns on by reset and will not let unlock screen.
SOFTWARE PROBLEM YOU HAVE TO GET THE MEMORY CARD OOUT OF THE BOARD FORMATT IT FULLY REPLACE SOFTWARE PUT BACK IN TAB DONE
Oct 12, 2012 | Coby Kyros 716829701508 Tablet PC
Cq60-212 laptop not trun on .black screen but power led on .ram is ok lcd also ok .i use laptop3 to 6 hour heat up laptop .now not trun on .
Hi
Have you tried to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
May 14, 2011 | Computers & Internet
When i trun the streeing seems to get hard to trun and sometimes then lock up for a sec...
check power steering operation at 3000 rpm, if it working properly, you need to replace yoru power steering pump. it is a very common problem on that year f150
Sep 06, 2010 | 2004 Ford F150
Will not trun on
Most desktops if the will not power on is a power supply issue .
Disconnect all external connections from the system except the power and see if it turns on. If it does, start adding items back on at a time and see what has failed. If no change, the next pull all expansion cards, try to power on. If no go, disconnect all power leads from drives and try again. If system still will not power on, replace the power supply
May 08, 2010 | Computers & Internet
Samsung Ln46A50 won't trun on
You need to get service for replacing the main board.
Nov 20, 2008 | Samsung LN46A650 46 in. LCD HDTV
Psp wont start
Might be the memory card inserted on your psp causing the issue, try to turn on your psp while the memory card is not inserted.
Sep 28, 2008 | Ubi Soft Asphalt: Urban GT 2 for PSP
HP PSC 2210 All-In-One InkJet Printer Logo
244 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
