Akaia Flat Screen TV Model #CFTD 1529w How can I durn off the Blocked - PG
  • motencw Apr 23, 2010
    I don't have a password and I've miss placed my manual. I have had this TV for several years but when we purchased it we had Direct-TV. Now with cable we get the blocked channel. PLEASE HELP!
  • motencw Apr 24, 2010
    I have tried to contact Akaia but I'm having trouble. Would you know the telephone number for customer service?
    Guru:
  • 416 Answers
Well, the initial password is "0000" if this does not allow you into change the parental control settings... you need to contact Akai for further assistance. Support for this TV can be found on this website: http://www.akai.com/contact.asp. Best wishes, I hope this was helpful.
Posted on Apr 24, 2010
  • Adam Halfhill
    Adam Halfhill Apr 25, 2010
    The only known phone number is the Singapore number listed on their website Tel : (65) 6476 6686. I am in US EST timezone... they are 12 hours ahead of us here. Try calling them after 9am, their local time.
  • Adam Halfhill
    What country are you in? You could also try one of the distributors in you country. Let me know, I may be able to find a more local number for you.
    Guru:
  • 374 Answers
I believe you are referring to blacked channels. If I am wrong let me know.
Go into your settings and scroll to where the parental settings/V-Chip setting is. It depends on what exact model you Akaia TV is but it should be under the first TV settings screen.
This input your password(if prompt to do so) and it will come up with options to change it. Go and chang it to what you desire to have it at. Some differ from other depending on what year the TV was made as they have changed the ratings system a few times in the past 10 years or so.
Let me know if you have questions or if you need a walkthrough.
Take it easy and I hope I could help!
Posted on Apr 23, 2010
  • Robert Dahmen
    Robert Dahmen Apr 24, 2010
    I am currently looking for a reset code. It's hard to come by. Have you tried to contact Akaia customer service??
What is pg blocked
sounds like a Parental Guidance lockout, check the settings on the TV preferences menu and turn off Parental Controls, you will need the TV Handset
Dec 13, 2015 | Sansui HDLCD3210 32 in. LCD TV
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Akai model cftd 2085
RCA JACKS,,SELECT INPUT IN THE MENU,,1,2,..AND SO ON
Jan 25, 2009 | Akai CFTD2085V 20" TV/VCR/DVD
I have a AKAI CFTD 2085 model tv. Is it digital or do I need a converter box?
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Dec 04, 2008 | Akai CFTD2085V 20" TV/VCR/DVD
I am looking for a akai cftd 2011 remote control
I need a remote for a CFTD 2011 for an Akai Tv/DVR
Sep 18, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
LCD TV MODEL CFTD 2011
If you do not get the same part, you can go in for a similar IC from a different company.
Try HERE:
http://www.electronix.com/
or
http://www.chsinteractive.co.uk/manufacturer_replacement_parts/
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 05, 2008 | Televison & Video
HDTV?
HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
Bill
Feb 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
