Question about LG Electronic Window Air Conditioner
New unit air seems not to be cold - LG Electronic Window Air Conditioner
  • 59 Answers
MAKE SURE ENERGY SAVER IS ON SO FAN SHUTS OFF WITH COMPRESSOR. AND MAKE SURE THERMOSTAT IS SET TO COLDEST SETTING FIRST. IF THAT DOSENT DO IT YOU MAY HAVE ANOTHER PROBLEM.
Posted on Apr 24, 2010
New Midea Air Conditioner system 3, does not seem to get cold air. Mode is on Cool and fan speed increase. Temperature at 20 degree.
More info needed. Is this a one-piece unit or a mini-split? Model number, any error codes, etc. More info will help
Jan 03, 2015 | Midea Heating & Cooling
My new ac unit isnt blowing out cold enough
What's the temp been out side? If its over 95 degrees only expect you air to blow at about 75. It's an air conditioner not a cold air maker.
Sep 02, 2012 | 1986 Toyota Corolla 2 Door
I have a roof top ac unit Model #7333C886 and someone is telling me that it cannot be recharged. Is this true cause it seems to be working fine other than not getting real cold. It is an older model I know...
It is a closed system, which normally they don't require recharge. It can be done but it is more or equal expense as buying a new unit. A lot of times a real good cleaning by someone who knows how to do it properly is all that is needed in cases such as yours.
Aug 23, 2011 | Coleman Mach 15 Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
I have a ruud ubhc-17j11sfd that does not blow cold air. it blows room temperature air only. the unit seems to run ok and the outside fan runs ok also. The filter is cleaned and the thermostat is set to...
Hello, if the airflow seems good and the unit is clean it is possible that the unit has a low refrigerant charge due to a leak, if you have a thermometer measure the return air and the supply air, tjen find the differance between the two, if it is below 15 then the unit is undercharged and will neec to be recharged.
Jun 15, 2011 | Ruud UBHC Air Conditioner
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Will not heat below 40
2nd stage heat should kick in on auto defrost ,sounds like bad sequencer or relay
Jan 27, 2009 | Intertherm P3RA-036K Air Conditioner
LG Electronic Window Air Conditioner Logo
144 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
