Question about Maxtor Hard Drive
I bouhgt a kit to hook up my internal sata hard drive to my laptop usb port.. i hook all up and including the power supply to the drive...when i go to my computer it does not show up.. i then go to my computer> control panel> admin tools>computer management> disk mangement> and see nothing there.. tried another laptop and different hard drive.. tried the usb kit on one laptop with windows xp srvc pk 3 and also on laptop with windows 7 any help thanks
  • 6 more comments
  • kevin butler Apr 23, 2010
    I already had them send a replacement kit under warranty and i have two hard drives i have tried one is 750 gig other is 200 gig.... i thought that a hard drive being sata that the jumper had no effect.. but i wil try that.........no change the hard drive does say the the jumper has no effect on sata
    very true on testing.. i tried jumper in all positions no good and this is the second kit i did receive it...when i rehook up the sata cable windows does make the " bloop bloop sound "
  • kevin butler Apr 24, 2010
    the hard drives are used and one should have os on it.. the main laptop i used is a hp hdx18 dual core with 500 gig hd..it has bee on and dsitting for 5 hours now to no advail.
    although very good suggestions it still has not found hd.. any other suggestions.. thanks
    i have already reported bad kit and received a warranty kit and tried it no avail..the 750 gig is a western digital..the 200 gig is also a western didgital. the maxtor was a 150 gig..the 200 gig is hooked up now and i do feel the drum spinning and do hear clicking or cycling sounds from it
    after leraving it hooked up for awhile i looked under control panel> system> then expanded disk drives now i do see one labeled usb to ide/sata device usb device...this is under device manager.. but still do not see anything under my computer any ideas
    ki
    NO I DO NOT SEE IT IN DISK MANAGEMENT ONLY UNDER SYSTEM> DISK DRIVES UNDER CONTROL PANEL
  • 344 Answers
Make sure the drive jumper is set to MASTER and try again, is the drive spinning up? Turn on the power supply and let drive spin up then plug into laptop via the USB cable.
Posted on Apr 24, 2010
  • Tony Groves
    Tony Groves Apr 24, 2010
    Sorry my mistake, I don't think SATA has jumpers! But try powering on before plugging in USB.
  • Tony Groves
    If you see it in device manager you should also be able to see in disc management, it may need formatting or just assigning a drive letter.
    President:
  • 1,851 Answers
Sometimes these kind of kits have problems at the controler state and are unable to recognize the drive. Have you tried to change it to a new one at the shop that you bought it?
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • 922 Answers
You have done an excellent job of narrowing down the problem.
It is clear that either the drive has failed or you have a defective USB adapter kit.
My guess is that it is the hard drive. Maxtor, in my experience, is the most unreliable HD manufacturer...ever! Especially if you don't hear the sound of the disk spinning up or the arm clicking across the disk.
However, you should keep with your troubleshooting process. All you have to do now is try the kit with a different hard drive or a different kit.
Then you will know if it is the hard drive or the kit.
Good luck, I hope this helps.
  • Jax Planet
    Jax Planet Apr 24, 2010
    If you can see it in disk management you are home free.
    Look up "assign drive letter" in Windows Help.
    Once you assign it a drive letter you will be able to access it in Windows.
  • Jax Planet
    Okay, let's review what you have done since isolating it to the kit or the drive...
    You are using an Administrator-level account when connecting the drive, right?
    You have tried two different disk drives, right?
    You have tried two different USB kits, right?
    You have tried both disk drives with each kit, right?
    You have tried each combination on a different computer, right?
    If you have answered NO to any of this queries then do some more troubleshooting until you can say YES to all of them.
    I am very certian that you are close to finding the cause of the problem.
    Don't let frustration get the best of you. Keep at it!
  • 6,993 Answers
there are two things involved, its either you need to set the hard disk jumper, or the kit you bought is not good. Also, are you sure the hard disk is still working?
To set the jumper, check the back of the hard disk, beside where the IDE cable or where the hard drive power socket is, you will see a black rubber/plastic, remove the rubber/plastic and fix it to the next pin, then test the hard drive again. If that doesn't work, fix it to the other pin, and so on.
If after setting the jumper and the problem still persists, Then you need to return the kit from where you bought it and take another.
You can as well test the kit with another Hard disk, to be sure your hard disk is not the one that is faulty.
I hope you understand my message.
Good luck.
Posted on Apr 23, 2010
  • Walesarumi
    Walesarumi Apr 23, 2010
    yes that's true, but in a situation like this, you have to try everything in order to know precisely where the fault is coming from.
    Did you just send for the replacement or you have received the replacement already?
    Good luck.
  • Walesarumi
    Okay, connect the hard drive to your PC and leave it for a while, as the system might recognize it later. Since its a new one, it might need time to load.
    Also, consider the fact that your hard drives are 200 gig and 750 gig respectively. These hard drives are large in size, so you need to use it on a PC with a standard configuration, that is, a PC that has a large memory size, dual processor, and large hard disk size.
    All these has to equal with your external hard drive. If the external hard drive is very much larger, it might take time for the PC to load the external drive.
    I hope this makes sense to you.
    Take care.
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
I have western digital external hdd usb 2.0 and i have opened it now i want to connect it as internal hdd, its a sata drive inside when i opened the cover
The specific connection depends on the form factor the hard drive mechanism and the computer in which you want to install it. If it's a 3.5" drive and you want to put it in a laptop, forget it; it won't fit in there.
If you want to put a 3.5" drive in a desktop system, you need a SATA drive power connector from the power supply, a SATA data cable, and a SATA port on the motherboard or an expansion card. (note that you will probably not be able to boot from this drive if it is connected through an expansion card unless your computer's BIOS supports booting from a PCI device). It's also highly desirable to have an empty drive bay in which to to mount the unit.
If the hard drive has a 2.5" form factor (2.5" wide), and it is to go into a laptop, you will need the 2.5" hard drive adapter for your particular laptop (many manufacturers have a special cable or adapter for hard drives, although they should all fit the SATA interface. However, if your laptop is an older model designed for PATA IDE drives, the STAT drive will not be compatible.
To put a 2.5" SATA drive in a desktop computer, you need an adapter kit. This includes a 2.5" - 3.5" drive mounting bracket adapter and a cable adapter connector for 3.5" drive connections as described in the second paragraph above. Many computer parts merchants carry these.
Sep 21, 2014 | Computers & Internet
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Mar 20, 2014 | Western Digital WD Caviar Blue WD3200AAJS...
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Setting up hard drive to usb connection
Either:
* the USB cable is defective;
* the USB-to-SATA interface is defective;
* the SATA disk-drive is defective;
* the power-supply to the disk-drive is defective;
* the parts are _not_ "defective", they just are incorrectly connected.
Try a different USB cable.
Try connecting the disk-drive as a "slave" drive into a desktop computer that supports SATA, to see if the drive itself is OK.
Use a multimeter to measure the voltage/amperage emitting from the power-adapter.
Do you hear the disk-drive spinning?
Does it produce any heat, when it is spinning?
Apr 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor Hard Drive Logo
206 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
