Question about Maytag MDG7600AW Gas Dryer
My Maytag MDG7600AW gas dryer doesn't dry clothes any more. It take over 3 hours to dry at first. but now it won't dry any more. After reading the posts here, I open up the front panel and clean up all the lints. After that, I test run and see the ignitor turn red, gas come out and so the flame. However, the flame only last a min and it is gone. Is that because I have my dryer door open? (have to in order to see the flame and testing)and how long the flame should stay on? PlEASE help.... thanks..
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Apr 23, 2010
Testimonial: "Thank you Marka 19 for your feed back. Based on your input, I expand and learn a lot more on its component. It turns out that I need to clear up my dryer vent. Here is a tip for all "dummies" like me, cleaning the dryer vent means hiring a professinal to clean the vent like duck work. "
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
The pilot light isn't on and wont light up, no smell of gas either. The dryer was working normal I thought, open the door and the clothes weren't dry.
You will need to replace the Thermocouple. You can purchase one at your local hardware store, the instructions will be with it. Very easy to repalce.
Sep 14, 2011 | Maytag MDG7600AW Gas Dryer
My Maytag dryer MDG7600AWW doesn't dry at all anymore.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 25, 2011 | Maytag MDG7600AW Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG7600AWW not staying hot
Hi, It sounds like that the coils on top of the gas valve are not opening the valve later in the cycle. They get weak enough ovwer heat and will not open the valve. You can listen for the ignitor to click on and then you can hear the gas ignite. If late in the cycle you hear the igniter click and then no gas ignition, change the coils.
You should also make sure the vent going to the outside is clear of any lint or kinked.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Maytag MDG7600AW Gas Dryer
MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Nov 23, 2008 | Maytag MDG7600AW Gas Dryer
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
609 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
