Question about Maytag Dryers
The heat stays on on my dryer even when its turned off. i have to unplug
    President:
  • 949 Answers
You have one of two issues, the most likely will be first.
- The heat element is shorted. If the element breaks and touches the metal shroud it can be activated and on all the time. You would need to replace the element. This can be seen by physically looking at the element or making a continuity test from the element terminal to ground
- The centrifugal switch internal to the motor is stuck in the closed position this can only be tested with an ohmmeter and if bad the motor needs replaced
Posted on Apr 24, 2010
Kenmore 11086180100 heating element stays on even when dryer is off
The control relay is bad. Internal contacts are most likely welded together. Replace the relay.
Oct 22, 2016 | Kenmore Dryers
Need help! If there is time left on the timer and I open the dryer door, the dryer tumbler stops as it should. BUT, my dryer heating element stays on and never turns off unless I unplug the dryer or turn...
Either the centrifugal switch on the drive motor is stuck in the ON position or the heating element is broken and shorted out on the heater canister.
You did not post a model number.
Therefore I can not assist in accessing these parts.
All dryers are made differently.
Appliance model numbers are a must.
Aug 14, 2010 | Dryers
Drying cycle doen't seem to turn off ....just seems to cook. Had to turn unplug the unit.
if this is electric dryer your heating element had short to ground cause element to stay on even if the dry turn off
Apr 25, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
The dryer keeps warm even when off. Why? The dryer remains hot even when off. It stays warm/hot days except when I unplug it. Why is this happening?
Hello, I suspect this is a electric dryer, the problem is caused when the heater goes bad, The winding on the heater will break and touch down to the chassis of the dryer which in turn will make a cicuit bypassing the switch. Replace the heater and your all fixed. Mike
Oct 21, 2009 | Hotpoint Dryers
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
My GE DHDSR46EE1WW Dryers heating coil won't shut off...ever!
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Jun 14, 2009 | Dryers
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the...
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
May 28, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
