Question about Linksys Wireless-G WRT54G Router
Hello bradnelson this is Ginger98. I am still working on my router problem. It will not connect. I am signed in under some network I found on a list called netgear
  • Anonymous Mar 27, 2008
    connection problem
  • 46 Answers
Ginger,
Try to contact me today, I should be online for most of the day and night.
Thanks,
Brad Nelson
Posted on Mar 24, 2008
  • Brad Nelson Mar 27, 2008
    You still here Ginger?
Hello , I have AT&T internet , and i sign to the internet using a wireless router , the issue i can not get my i phone to connect to the network even though it detect the wireless signal and i sign...
Can you indicate the model of your phone? And do you have any other computers/gadgets that connects to the wifi? Because if you do, you need to focus on the phone and try not to mess up w/ the router yet . Perhaps tyr to "forget the network" and reconnect back. if this diesnt work you can chage wireless seurity settings or add the IP addreess manually.
Dec 18, 2012 | NetGear WGR614 Wireless Router
How to get my SSID?
Hello there,
The SSID is the Network name. You have to login to your Wireless router to get it.
Mar 15, 2011 | Buffalo Technology WHR-G54S Wireless...
I hooked up my wireless router to my modum but no internet is going out to my laptop
Open the router's GUI with 192.168.1.1 if it is a linksys/netgear router login with username - leave blank password - admin for linksys router
Click on wireless tab on top- Select Manual - Wireless n/w mode - mixed, Network name SSID(Remove linksys and type the name you want to give to wireless network), Radio band channel- Std.20Mhz. Wide Channel - Grayed out,Std.Channel-6.2.437GHz. , Broadcast of SSID - Enabled,Save settings, Click on wireless security (Under sub tab of wireless) - Security mode - WPA - Personal - Type the password you want to create for wireless. Try to search for wireless networks and try to connect. At times you not able to connect - So try to remove the preferred networks from list.
Synario for win xp -
Start - Control Panel-Network and internet- Network Connections - Rt. click on w/l n/w connection - View available w/l n/w - Click on Changed Adv. settings - Click on w/l n/w tab in btwn the general and advance - Remove the prefrerred networks from list. And now click ok - come out from ever y window and click on the pop up whuich says network detected/One or more n/w found in range- Click on the w/l name belongs to you - And hit connect - Type you security key and all set.
At times you not able to see w/l tab btween general and advance -
Thn Click on start - type services.msc in run - Rt. click on Wireless Zero Configuration (Myt be last or second last option from list) Click on start- And now try to connect to w/l after removing the preferred networks from list.
Apr 01, 2010 | NetGear WGT624 Wireless Router
My wireless laptop worked fine until i returned from vacation. Now i can't sign onto the internet. It says isp or no newtwork. What happened when I used this on vacation under my cousins router?
Check under network connections and see which network is set to default You may be trying to sign on and connect to the wrong network.
Please rate my help++++ Thanks for using FIXYA
Nov 24, 2009 | Microsoft MN-700 Wireless Router
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Wnr834b passphrase won't work
Hello jsnow4 & cooler34788,
For vista OS;
Here are some troubleshooting steps that I suggest you try:
1. Go to "Control Panel" ( switch it to classic view )
2. Click " Network & Sharing Center"
3. At the left side of " Network & Sharing Center", click Manage Wireless Connection ( under task)
4. Delete the profiles of your Wireless connections particulary the one you named for your Netgear wireless ( this is also known as SSID).
5. Click close including "network & Sharing Center"
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
Since this is an unsecured wireless, Vista will warn you if you wanna connect anyways. Go ahead and connect.
From the above configuration, please check if you can now access the Internet.
Jan 31, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
I cant get my laptop to connect to my 2wire how do I do this
Connect to the router from the desktop and enable wireless.
if you have windows XP
Click on the start menu, go to run
-> in the run prompt type: ncpa.cpl
--> right click on you wireless network connection, go to the wireless network tab, removed your network from the list of prefered networks
---> now try to re-connect
if you have windows vista
click on the start menu, go to the control panel, look for an icon called network and sharing center (switch to classic view if you don't see it), then go in the tasks to "manage wireless network connections" and remove your network from the list using the green minus sign button
Dec 17, 2008 | 2wire HomePortal® 1800HW Router...
Wireless router belkin n1
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Laptop connects, but main computer doesn't....
if you have the router set to enable dhcp which gives your network cards an ip address automatically, then check that the network card of the main pc is set to obtain ip addresss automatically, this is in network connections, right click on network connection icon, properties and on the TCP/IP line click properties and check that 'obtain ip address automatically is ticked, apply and ok. Igf you have tried to repair the connection using wizard, then your settings will have been changed, thats possibly the problem. Also go into the routers settings and see if the main pc is listed under dhcp clients and that an ip address is given.
May 16, 2007 | Belkin (F5D5231-4) Router
Linksys Wireless-G WRT54G Router Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
