Question about GE Profile 30" Slide-In Gas Range - Stainless-Steel
Have new part in hand
How to take front panel off to install new erc. JGSP31GER3WG
Did you ever figure this out? I need to remove my front panel and am not sure how to do it. Thanks.
Posted on Sep 30, 2010
Why does FF come on my GE oven when it is in the self-cleaning mode
hello,
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
pcappliancerepair.com appliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourself offer.
If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
thanks.
Oct 09, 2010 | GE JTP75WMWW Oven
Ariston FB 97 c error 08
hello,
This error code on a Kitchen Aid range (oven) indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.comappliancepartspros.com repairclinic.com
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourself offer. If you decide to order the part and wish to repair this on your own, follow these steps:
Oct 09, 2010 | General Ovens
What does F2 error code mean?
hello,
searspartsdirect.com repairclinic.com
thank you and thanks for using fixya.
Oct 09, 2010 | GE Ovens
I get an F-21 error message
This error code on a WASHER indicates a keypad short on the Electronic washer Control (ERC) board.
or an over flow of water in to the panel of the washer detected by the lens reader.
However,this is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.com repairclinic.com
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourselfer. If you decide to order the part and wish to repair this on your own, follow these steps:
hope this solution help?
Thank you.
Oct 06, 2010 | Kenmore HE2 Plus Front Load Washer
Oven beeps with f7 code , replaced display pcb . oven still beeps replaced front touch pad , now cooling fan comes on and after a while oven beeps with no error code . and blower fan button does not work ,...
hello,
(indication of problem)
This error code on a oven indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.comappliancepartspros.com repairclinic.com
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
I hope this information helps you.
thank you for using fixya.
Oct 03, 2010 | Jenn-Air Ovens
Oven displays FE error and shuts itself off, impossible to get anything to cook!!
thanks
Oct 03, 2010 | Ovens
Error code f3 when oven is started
hello
thanks for visiting fixya.
Oct 03, 2010 | Magic Chef Ovens
Error f 35
This error code on a washer machine indicates a keypad short on the washer Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
I hop this information helps you.
thanks.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 2?
hello,
This error code on a washer machine indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
thanks.
Sep 29, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Upper (broiler) element won't turn off causing thermal runaway
This is caused by a stuck broil relay on the Electronic Range Control (ERC) board. In most cases you will need to replace the ERC.
repairclinic.com
If you have any questions about this repair, please post back with you complete model number, so that I may bre able to provide you with better assistance. I hop this information helps you.
NOTE: In the interim, if you still want to use the range, you can unplug the appliance, remove the back panel and disconnect the two wire leads going to the broil element. Trace the wires back from the broil element to the ERC and disconnect them. Tuck the wires out of the way.
Dec 27, 2009 | Kitchen Ranges
GE Profile 30" Slide-In Gas Range - Stainless-Steel Logo
124 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
