Question about Brother IntelliFAX 4100 Laser Fax
Vertical Streak on my sent faxes
There is a vertical streak tha prints on all of my sent faxes. I changed both the toner and the drum and the problem continues.
    President:
  • 3,085 Answers
Open up the document feeder and clean the scanner glass. If the streak is larger than 1/4 " wide, you have a bad scanner block.
Posted on Apr 23, 2010
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
The faxes being sent print out with vertical lines down the middle
There is a little scanner in the fax machine that reads the page so it can be sent out. You should be able to open the top, similar to changing the toner, and locate the scanner. This should have some glass over top protecting it. Just take a damp cloth and clean that piece of glass. There is most likely a small piece of dirt on the glass, but when it scans paper it looks like a big streak.
Jan 10, 2011 | Samsung SF-560 Plain Paper Laser Fax
Wide black streak
Yes, you have a burned out scanner block element. It's cheaper to buy a new fax machine
Mar 30, 2010 | Brother BRTPPF4750E...
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Vertical Stripes on printed Page, Shaken Toner, Relatively new Belt (Green thing), cleaned the fuzer wire, cleaned the cleaner roller, has oil.
Depending on the type and model of your printer this could be several things mostly related to the cartridge or drum if you have a separate toner/drum system.. Since you have stated you have shaken the toner, I am assuming you have a laser printer. New belt, has me confused. Green thing leads me to think you are talking about the drum. If so, did you purchase a new toner cartridge or new drum cartridge?
Several components inside the toner or drum cartridge will cause vertical streaks. It depends on where these streaks are occurring and how wide the streaks are. We call these repetitive defects and they can be measured to determine which part is at fault.
Also, if this is a multi-unit machine (print/copy/fax/scan) Check the platen glass or ADf feed unit for white out. That has been a major culprit of vertical streaks on the page.
More specifics about the model of machine and cartridges being used would be helpful in trying to solve this problem for you.
Nov 14, 2008 | Brother Office Equipment & Supplies
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Vertical line when using document feeder
Look really close at the small glass strip. There will be toner embedded in the glass. It will probably be a very thin streak though, so hard to see.
Jan 30, 2008 | Dell 1600n All-In-One Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
220 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
