Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 43PP6360/79 I have this Rear Projection TV and the Picture is very poor with lots of blue haze. Is this a convergence problem? if so how can I adjust it. I can't find Q-8 which is suppose to refer to convergence
  • Philips Master
  • 8,617 Answers
If the hase your refering to a glowing halo its the blue coolant that needs changing. If it causing a 3D image then its the convergence ICs need changing
Posted on Mar 23, 2008
SOURCE:
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Phillips TV Model No. 46PP93 0217. The
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Philips 46PP9302 46" Rear Projection...
Blue haze in picture you see like a blue shadow of the person in the picture?
you probably have a convergence issue. there are many posts with repair and photo help. just fixed mine today by replacing the convergence chips and a pico switch. picture is better than ever. try searching "convergence chip" with your model #
Jan 05, 2010 | Sony KP-57WS500 57" Rear Projection...
Red, green and blue colors don't match up on screen.
Please replace convergence out ICs (usually two) in TV.
If it is Hitachi 43UWX10B then its convergence out ICs are available in Part Store
Thanks.
Aug 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hi i have a phillips 43pp6360/79 it has a very cloudy over bright picture. Also when adjusting the blue convergence the second cross dosent appear anywhere but a slight blue haze moves around the first...
I'm not quite sure about the convergence issue, but the glowing white haze is a sign that the fluid in the color tubes is dirty and usually can only be fixed if the fluids are changed out(draining and refilling). This is not recommended for someone who does not know what they are doing, it is best to get an expert to do this work because it can be dangerous as well as hazardous to your television and quite expensive. Mostly all rear projection televisions will have this issue, but I find that just upgrading to a newer-model television is usually better, maybe a flat panel LCD(Liquid Crystal Display)(stay away from unknown brands and plasmas, although Vizio's LCDs will get you more bang for your buck). On an LCD, all you really have to worry about is cracking the liquid-crystal display, which is quite fragile, but can be avoided if no hands or objects touch the LCD. On the other hand, best of luck in fixing your Philips rear-projection.
May 16, 2009 | Philips 60PP9202 60" Rear Projection...
Blue haze on the lower part of rear Projection TV
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Blue Haze
thats how my stared than got worse i call for service and got fix after 4 moths had the same problem and i called the same guy again at firs he told me that the convergence was bad and replaced them i think there are three pieces but than the second time he took the box inside the tv he checked all the circuits and the board and he found out the something else was getting real hot and was causing that the convergence to bad now he fixed hope i got no more problems
Apr 30, 2007 | JVC AV-65WP55 65" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
392 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
