Question about Spectroniq PD-1100 DVD Player
When inserting a dvd...says loading...then wrong disc. have cleaned the optical reader and tried several other dvds same result
    Genius:
  • Spectroniq Master
  • 1,550 Answers
Change the motor disc spindle
Posted on Apr 24, 2010
When i insert a dvds the display keeps flashing loading and won't play the dvds
Clean the optical pickup lens. Use a lens cleaning disc. If it do not help you, replace the optical pickup unit.
May 27, 2012 | Sony Televison & Video
My optical drive cannot read burned data dvds. However, it can burn data dvds which can be read on other computers. OPtical drive can read dvd movie discs! I cleaned the lens several time in last few...
you need to understand the mechanics behind cd/dvd reading, writing and burning. It usually means the reader is calibrated to a different layer than the dvd was burned on. Check this site for clarification. It's not my site but lots of detail on cds and dvd processes.
http://www.explainthatstuff.com/cdplayers.html
Sep 07, 2017 | Lenovo Computers & Internet
Dvd player says no disk when inserted even after cleaning
Hi, the optical unit in your combo needs to be replaced, unless the cleaning disk has not been tried enough. Perhaps it's time to have it cleaned professionally. Try the cleaning disc several times and see if you are able to get the disc to load, one idea for you, try an audio disc and see if it reads it(loads it) if it does play it then for sure you have to replace the optical(the dvd side of the unit is inefficient).
Nov 17, 2010 | TruTech T2000D TV
Will not play a dvd. When a dvd is inserted the screen says disc loading for a few (5-10) seconds then the disc is ejected. We had an identical unit that did the same thing about 7 months ago so we...
good day, regardless of the brand it maybe an optic lens problem but i suggest that you buy something branded, much better and worry free. hope this helps
Feb 11, 2010 | Legacy LDVD74 - - Mobile Hi-Fi Stereo...
I power it up and insert a disc and it says Wrong Region on the screen. This is a Canadian unit that has worked fine for two years now, and I've tried several different DVDs which work fine on my larger...
If you have relocated then the region code may need to be changed. However using region 0 is most practical. Clean the optical head of the player with a CD/DVD cleaner too & see if it responds............sodeep
Sep 25, 2009 | Mustek MP70C Portable DVD Player
Daewood DVD-5700 DVD Player ~ Won't play any DVDs
Hi.
There could be several reasons for this problem.
Since the unit has not been used much the lazer
shouldnt be burned out...but it can mean that it collected dust by not being used.
How is the condition of the disc you tried to play?
Are there children in the family...they love to put things in the tray and load it in. =)
A cleaning kit might help if there is dust on the lazer lens.
Regards...
/Tech5508
Feb 14, 2009 | Daewoo DVD-5700 DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
When I try to watch ANY DVD, after loading, the screen says "bad disc"
hello,
Sounds like you need to clean the optical lens on the inside of your player. You can do this the easy way and purchase a dvd cleaning disk or you can remove the cover of the dvd player, there will be a couple of screws on the side and a couple on the back. Once you have done that, open the cd tray and unplug your player from the outlet. Now take some cu-tips and a small amount of rubbing alcohol and lightly dip a cu tip in and look inside your player. You will see a small glass bubble inside the middle of the carriage that will be the optical laser reader. Gently swab off the optical lens a couple of times with each cu tip dipped in a small amount of alcohol. It would a good idea to also purchase a can of compressed air and blow your system out to make sure it is clean of dust and dirt. Make sure you blow the system out before cleaning the optical lens. Let dry for about 2 minutes before plugging back in and replacing the cover. Now try and play your dvds. You might also want to clean each dvd before placing them in your player as an added help. I hope this helps and let me know if you are still having problems because it could be a defective part and I will be able to let you know what it is with a few more questions and the answers you give.
If you do not mind please rate my help, I would really appreciate it. Thanks
Jul 09, 2008 | Cyberhome Televison & Video
Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
May 25, 2008 | Denon DHT500SD System
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Spectroniq PD-1100 DVD Player Logo
142 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
