Question about SAMTRON 94B 19 inch LCD Monitor
Samsung 19 inch lcd monitor turns on and right back off
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 24, 2010
My 510 sync master monitor comes on when i press the power button but goes right back off
Any FIFTEEN-inch screen is very old.
Responsibly recycle it, and buy a new 19 or 21 inch screen.
Your eyes will thank you for having the much-bigger screen.
Oct 30, 2014 | Samsung SyncMaster 510N 15" LCD Monitor
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
Monitor SAMSUNG 961BF does not turn on no picture?
  1. Verify that the power cord and Monitor cable are securely connected and not damaged. Unplug and replug these cords back in and test functionality.
  2. If the monitor still ceases to function, you may have a bad board, lcd screen, or inverter.
  3. I recommend replacing the monitor unless you are familiar with testing and replacing electronic boards and LCD screens.
Sep 12, 2011 | Samsung SyncMaster 961BF 19 inch Monitor
The Lcd as not working
Spend $50 to $100 to buy a new 17-inch or 19-inch LCD monitor.
Or, spend that much to have a qualified technician *TRY* to trouble-shoot, and hope that he/she does NOT tell you to spend $50 to $100 to buy a new 17-inch or 19-inch LCD monitor.
Oct 23, 2010 | Samsung 15.3" LCD Monitor
When i turn onmt Samsung SyncMaster 920LM 19 inch LCD Monitor it blinks on the left upper corner for a few moments
WQhen you get strange problem like this, first place to look will be the caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2010 | Samsung SyncMaster 920LM 19" LCD Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Samsung LCD 19" monitor problem
Does the monitor plug into a card or the motherboard socket?
Mar 25, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
SAMTRON 94B  19 inch LCD Monitor Logo
81 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
