Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The agitator doesnt move- in the wash or rinse cycle
    President:
  • 1,430 Answers
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Apr 23, 2010
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Agitator won't move on wash cycle or rinse cycle
I've had that happen before, and it was something to do with the weight of the clothing in it? Would be more helpful if you put in brand name and model.
Mar 31, 2014 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Fws445rf1 washer didnt stop filling and flooded my apt and it doesnt aggitate when it is washing,the whole thing just spins inside instead of moving back and forth,what are the most likely reasons for...
if it's a top-loader, then the water level sensor is probably failed! if an older machine- there's a plastic tube (which you can't see from the outside) that measures the column of water in the tub of your machine, and triggers the agitate and spin, and rinse cycles of your machine.
when it's in wash cycle the water level is lower, then it spins and drains and the rinse cycle pumps in more water (makes sense!), then drains & spins, then re-rinses at the same water level. your water level sensor is defective, probably. allowing it to over-fill.
it detects the water level as 'spin' and doesn't agitate!
my theory- no guaranty! if it's old get a new washer or a good used one! this is not a problem i've encountered, just a guess. good luck!
Apr 17, 2010 | Frigidaire FWS445RF
Washing machine stuck between wash and rinse.
first remove agitator by taking top of agitator off and putting your hand down the centre of it and unscrewing the wingnut holding the agitator to the main drive shaft. once the nut is loose pull the agitator out and bail the water out by hand using a pot or jug. once the bowl is empty u can look underneath. to the right hand side front of machine u will see a red or black fan that is attached to the pump. turn the fan clockwise and then anti clockwise and hopefully that will unjam the pump. the fan should turn freely. then put machine back on its feet.refit agitator. turn on unit select spin and it should start draining.if it doesnt reply back and i will help u more. please turn off power to unit b4 u work on it. good luck
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
Agitator seems to bind up when in wash and rinse cycle
you need a new coupling between the motor and the transmission.
Mar 07, 2009 | Washing Machines
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
