Question about GE WJSR2080V
Water drainage problem
After the rinsing cycle, the water doesn't drain out of the machine. what could be wrong?
  • chip3833 Apr 06, 2008
    machine will not drian water after rinse cycle. Possible drain clogged???
  • 43 Answers
Faulty pump or drain pipe is clogged
Posted on Mar 23, 2008
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
I have an haier washing machine that gets stuck at the rinse cycle. What could it be? Plus it makes loud grinding noise.
are u saying its putting water in the draining over an over? or not rinsing at all? if no water coming in check water inlet valve. if its draining over and over>? check ur drainage and water pump
Jun 15, 2015 | Haier Washing Machines
What does half 6 E error code mean on LG washer
make sure the drain hose is higher than the back of the washer, has to be to function the draining of the unit.
Jan 02, 2015 | LG Washing Machines
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
When the wash is finished it doesnt drain the
 Make sure that there is no blockage in the drain hose and that it is not kinked.  Is the drain hose installed correctly?  If you have connected your machine to a sink waste system, make sure that you have cut out the membrane from the under sink drainage system.
 Ensure that the drainage system, standpipe or under sink connection is free from any blockage. - If any of the above are found to be the cause of your problem you will need to run the machine through a spin only programme.  If you have chosen ‘Rinse Hold’, the light will flash until you press the ‘Rinse Hold’ button to continue the programme.
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
49 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
