I have a JVC, AV48WP34, with the following problem. The DCU is defective on the convergence module. This was verified by installing it in a serviceable set. I ordered a replacement module and the original failure was corrected, but a new one appeared. When convergence is attempted the blue and green crosshairs are present but the red crosshair is not. It does not appear even when the screen control is turned up. I assume that whatever is causing this red failure may have damaged the original DCU. Anyone have this experience or an idea what might be happening?
  • 3 more comments
  • Phil Day Apr 24, 2010
    Evidently you did not read what I said in the original note. I am a servicer and already did what you suggest before ordering a replacement SSB-5051A. I verified it is good by checking it in my serviceable set. The problem is some where in the signal board. You need to pay attention. SOME WIZ YOU ARE.
    I verified the new unit is good by checking it in my serviceable set. the problem must somewhere in the signal board area.
    I verified the replacement board is good in a serviceable set.
    Do you have another solution to my problem?
  • Phil Day Apr 25, 2010
    The replacement convergence module checked good in a serviceable set.
    Genius:
  • 1,043 Answers
I had an issue similar to yours and found the information at the following website extremely helpful:
http://www.hometheatershack.com/forums/diy-repair-maintenance/5600-crt-based-rptv-convergence-repairs.html
Hopefully you will find the same.
Posted on Apr 25, 2010
  • 1,512 Answers
Hi Phil
Couple of questions for you bout the problem.
  • Where did you get the replacement board from.
  • Is it a second hand or salvaged part, or new from manufacturer.
  • Does it appear to be used at all.
I would remove and re-seat all connections to and from the board also. I ask about the origins of the board, i have had faulty reworked boards from suppliers previously myself. Or may have come out of a problem set and recycled for spares. Is worth checking with the suppliers of the part for any warranty they offer, and use this to help get to the bottom of the problem. It may mean getting another board, to eliminate it as an offending part.
regards robotek
Posted on Apr 24, 2010
  • Graeme Ross
    Graeme Ross Apr 24, 2010
    Sorry mate... the system did not allow me to see your comments till after I posted, "already verified board a good worker in other set". My advice not much help to you either.
  • Graeme Ross
    Graeme Ross Apr 25, 2010
    I am a advocate of Murphy's law. Sometimes, for inexplicable reasons, a Tech can face the most confusing circumstances, often bearing totally ZERO rhyme or reason.
    In my more than 20 years running service departments for electronics, strange problems will periodically prevent the progression of a job. This could be on a set of unknown reasons for its failure, and then the consequential new symptoms.
    • It may have suffered a power surge, a lightning strike
    • poor connectivity of disturbed connections
    • crappy lead free soldering
    • low quality parts
    Of course these failure inducing contributing factors can sometimes eventuate to situations where the original symptomatic fault is solved by replacing parts, to find that a completely new problem arises from the service work.
    I know that you as a tech as probably painfully aware of "the Curse". I know you are looking for a fix to the problem, but changing out further parts is the only way you are going to get through this one mate. If you have a serviceable set at your disposal, then you have all you need to get to the bottom of this.
    I hope that someone can allude to a more direct solution for you here, Good luck.
    regards
    robotek
    President:
  • 1,768 Answers
Surrounding components needs to be checked at the DCU.
There may be weak capacitors and or resistance at the voltage input and output points on the circuit itself there by damaging the unit. Incorrect voltages will cause IC's to fail over a period of time.
Posted on Apr 23, 2010
The focus on my jvc tv is out
is this focus or convergence? red green and blue outline would be convergence.
If this is your defect you have 3 integrated circuits in the convergence circuit that causes this defect. IT requires solder and alignment.
Please leave feedback
Feb 21, 2011 | JVC Televison & Video
Helloi have a problem with a panasonic 47wx49e in the convergencehorizontal red lines cant be staigthevery adjustin conventional mode are working but when i get inside of the dynamic convergence adjusts...
I would look for burnt resistors off the red IC, hopefully its not the DCU (digital convergence module) as most of these are integrated into the signal board. here is a tutorial i made up:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 26, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Jvc av48wp34 with green tint and center of screen sags down
hello take the a aerial out to see if the green tint is still there if it is the then you've got a degausser problem you
shaun
Jul 31, 2009 | JVC Televison & Video
Was convergence problem now dont know
often on that model the DCU which is on that same board is where the problem is especially if new ICs and resistors dont fix the Issue. The DCU is the metal cased unit which is next to the Convergence ICs heatsinks
Mar 14, 2009 | JVC Televison & Video
Samsung pcj522r
Its the digital convergence unit. If that goes out you will not have any control over the convergence. I have seen many times where the convergence ICs were suspected to be bad, and then after changing the ICs the set still wouldnt converge. the magic focus is controlled by the DCU often the magic focus will work only part way, then other times it will go farther then back to nothing. The DCU is usually suspect if more then 1 color is out.
Jul 26, 2008 | Televison & Video
Convergence problem for JVC Model AV48WP34
Replace both convergence Ics they are STK392-110. You can get replacement Ics at the following link with instalation instructions with pictures that are included with the ICs for free. Heres the link.
http://servicemanuals.vstore.ca/
Jul 02, 2008 | JVC Televison & Video
My av48wp34
The AV48WP34 is a lightbox PTV and therein could be your problem with the audio. If the box was removed for testing in the convergence it's possible that not all the jumpers are tight. Look at connection between pin 12 of T921 and K935 jumper for your 28v source I've made that mistake in this chassis before.
As to your convergemce problem it's most likely an amp failure. That unit takes two STK392-110 Sanyo amps and both should be replaced. On this unit convergence is easy through the front of the TV grill. The entire module can be removed for replacing the amps making installation a breeze if you're any good at soldering.
I'd recommend Acme for the amps http://www.acme-sales.net that way you won't get some chinnese knock-off... And you might even want to consider upgrading the amps to some STK392-150's (greater amperage) for greater reliability.
Bill
Mar 29, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV48WP34
Replace Convergenge IC's
Nov 06, 2007 | JVC AV-48WP30 48" Rear Projection...
Curved red lines across screen
hi there, i had the exact same problem as you and this is how we solved it. Instead of replacing the convergence IC's as suggested above, which requires soldering and de-soldering, which could damage your board (this happeend to us). Order online part # SSB-5068A. This is the ENTIRE convergence board with new IC's. Cost you about $140 (from vance baldwin.com) but is a lot less hassle than you trying to soldering/desoldering parts. Only thing is, next to the 2 large heat sinks, there is this large silver component that you need to unscrew from your old board, and unplug and attach to your new board. We tok the new board..hooked up all the wires..and voila, no more convergence issues.
Jul 09, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
