Question about Ryobi Garden
How do you remove the drum (Part Number: 308177001) on the Ryobi trimmer model # RY30544?
Use a torx screwdriver through the square hole and turn counterclock! I though it was clockwise, and I broke the bloody screw... The screw is glued...
Posted on May 05, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Repair manual for ryobi line trimmer rlt900
Jerry,
That number is not the model number for the trimmer, which always starts with RY. It is the number for the "bump head assembly" which is considered an accessory. They made 3 for this application as follows:
  • Bump Head Assembly, RLT1000, RLT900, RLT1004K
Once you determine your correct trimmer model number you can go to the link below and find your manual. Hope this helps.
RYOBI Product Manuals
Mar 29, 2015 | Ryobi Garden
How to fix the starter on trimmer
Depending on the model it probably will require disassembling the shaft drive end. If is a clutch model then that will need to be removed too in order to get the starter cover off. Once the clutch drum is off you will need to block the piston movement in order to remove the clutch itself. Partially filling the cylinder with starter rope will work as a piston stop if enough is fed into it.
Nov 08, 2014 | Ryobi Garden
Need to remove flywheel ryobi RLH1100 mark2
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Nov 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
How do I remove the clutch rotor assembly on a ryobi 720r?
I have the same model, I inserted a large screwdriver on the inside to stop the rotor assembly from spinning, then I used a pipe wrench (but channel lock pliers would probably work better) and then w/o much effort, I easily turned the wrench counter clockwise to loosen.
May 01, 2010 | Ryobi Garden
I have a 25cc Ryobi grass trimmer I have lost the manual. I would like the fuel ratio of petrol to 2 stroke for this trimmer
http://odref.com/pdf/Ryobi/
If you have your model number, an owners manual should be here with correct mixture ratio for petro to 2 stroke oil.
Sep 14, 2009 | Ryobi Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
How do i remove Drum & Connector. I have a Ryobi bc30,RY30004d. i need to remove drum and connector so i can clean and inspect IGNITION MODULE ? also there is alot of oil everywere why is that? Thanks...
When you say drum, I assume that you mean the flywheel. It doesn't need to be removed. There should be a screw holding the ignition module on. Just simply remove the screw.
As far as the oil goes, that's normal. Just clean it up a little.
Jim
Jun 16, 2009 | Ryobi Garden
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
78 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
